I vote PCV is allowing boosted air back into your engine, pressure builds in crankcase & pops the dipstick.
An inline check valve like this http://www.ebay.com.au/itm/3-8-10mm-Inline-Check-Valve-Fuel-Diesel-Gas-Liquid-Air-One-Way-Non-Return-/221127175541?pt=Pneumatic_Hydraulic_Valves_Parts&hash=item337c34ed75 could be a lot cheaper than replacing the PCV & will do the same job.
If size is wrong for your hose check other items for sale.
Thanks guys, ill take alook at PCV see if its blocked tommorow.
Someone told me my bottem end might be getting tired, hope not. Guess time will tell, the car dont burn any oil and dont smoke so im hoping its only something minor fingers crossed..
Doesn't sound good, PCV is a definate possibility. However, How many k's has your engine done? How often has it copped 18psi for? And lastly, how often do you change your oil? If you answer high, lots & not as often as I should, then rings are the most likely culprit. I'd recommend keeping the boost down, as high positive crankcase pressures are going to push oil into your intake, & then it will burn oil!!!!!
Have you fitted a oil catch can recently? I fitted one wrong once and it caused this same issue your describing now.
I had this issue once becuase I fitted an oil catch can and it had no breather/wasn't vented back into the turbo intake. This pressurised the crankcase and popped the dipstick out. I fitted a breather then the problem was solved.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
