Hello!
I went from a OS Giken TS2B to a TS3B. I also installed the Nismo slave cylinder with SS clutch lines so it got new fluid too.
I also changed the fluid of the transmission ( I don't know what is was before) to 2 liters of MT90 and 2 liter of Lightweight shockproof.
The clutch engagement ( clutch pedal) feel, IMO, smoother than it was before with the oem slave ( some says it doesnt do anything but I really feel it).
However, my major problem is the shifter! I have the impression I'm breaking the gears/shifter every time I try to go in 1st. IT'S REALLY HARD! getting in 2nd is a little easier and 3-4-5 is slightly ''stiffer'' but I don't mind it. Dowshifting is not really a problem ( i.e: 5 to 3)
It's really my 1st and 2nd that make the car less fun to drive than before. What could it be? not enought fluid? time for a nismo solid shifter?
thanks for the input!
https://www.sau.com.au/forums/topic/411915-gears-hard-to-get-in/
Do you have both Nismo clutch cylinders or just the Nismo slave + Nissan master?
Also did you know Nismo/Nissan only recommend the Nismo clutch cylinders for single plate clutches? (they go to the effort on a Nismo coppermix to say to not use Nismo cylinders)
2 possible causes there.
1. Not enough disengagement of the clutch.
2. Horrible mixture of transmission lubes leading to synchro wierdness. Why did you mix shockproof with MT90?
Heres my thinking; shockproof protect synchro, so I will add some LIGHT shockproof to the mix in order to protect our fragile synchro. I heard other people doing it. Maybe I was wrong.
Suck to waste 50$ of fluid but i've made bigger mistake in the past so I wont be mad about it.
Redline told me to try the car in reverse, if it feel correct, it means the clutch is disengaging correctly. does that make sens?
Edited by cobrAA
I have nismo slave and oem nissan master. dont think nismo make a nismo master anyways?
This stand correct for the COPPERMIX and nismo twins. but it doesnt stand for any other twin and or triple plate clutch on the market. Nismo use a different types of material for their clutch.
There is no synchro in reverse so this is why they will be telling you to try this
Regardless of what the problem is, drop the oil and put redline lightweight ONLY in the box. I don't like the idea of mixing oils
Probably right there, I could have sworn there was a nismo master.
Quoting from: http://www.nismo.co.jp/en/products/competition/clutch/pdf/clutch09.pdf
"Coppermix and non-asbestos clutch discs are equipped with cushion plates and should not be used with the big operating cylinder."
I don't know if the OS Giken falls into the above, but I have read other people use non-Nismo twins/triples and have issues with stroke (clutch engagement being too short) with the Nismo slave.
I'm not a fan of mixing gear oils either, I've never once read anyone on here mixing shockproof with another gear oil. It's always straight shockproof.
I asked Osgiken tech support about the nismo slave and they said it was perfectly fine. I can also admit it really make the pedal a lot softer which I appreciate. (or maybe my oem was giving up). But I know my mecanic told me he had a problem with the slave, the rod was too short I think, so he had to take the rod on my OEM and swap it with the one on the nismo slave. maybe the problem is here ?
I guess I will start by putting only MT90. ( this is what tech support at redline told me to do).
BTW, when I took the car to the gym I tried to play with the clutch and noticed that I could make the gears grind in second while downshifting from 3 to 2. It felt like when you accelerate too quickly and you didn't release completely the clutch pedal but I'm sure my clutch pedal was fully on the floor meaning I clearly have a disengaging issues.
Edited by cobrAA
Do you know how to rev match a down shift? After a certain point (in terms of gearbox loading and/or age) it becomes pretty much a necessity.
box and synchro have been rebuilt in a shop 2 years ago. never rev-matched my car.
Osgiken recommend to cut 4 mm off the center plate or the shaft .. my mechanic didn't do it. This might be the cause. However he can't see how this could change anything so before that I'm thinking about having him installed my old oem slave . if this ever resolve the problem, I'm worried about how the pedal will feel.
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
    • I'm happy with the Lsailt unit that I put in, it puts full Android on the top screen so you can run whatever Nav and other Apps you want, while still existing inside the factory functionality like automatic reverse cams, audio input switching, retains factory bluetooth etc. Not cheap and the install was moderate (not simple, not hard) Yours is a V36 not V37 though right?
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
