Hello!
I went from a OS Giken TS2B to a TS3B. I also installed the Nismo slave cylinder with SS clutch lines so it got new fluid too.
I also changed the fluid of the transmission ( I don't know what is was before) to 2 liters of MT90 and 2 liter of Lightweight shockproof.
The clutch engagement ( clutch pedal) feel, IMO, smoother than it was before with the oem slave ( some says it doesnt do anything but I really feel it).
However, my major problem is the shifter! I have the impression I'm breaking the gears/shifter every time I try to go in 1st. IT'S REALLY HARD! getting in 2nd is a little easier and 3-4-5 is slightly ''stiffer'' but I don't mind it. Dowshifting is not really a problem ( i.e: 5 to 3)
It's really my 1st and 2nd that make the car less fun to drive than before. What could it be? not enought fluid? time for a nismo solid shifter?
thanks for the input!
https://www.sau.com.au/forums/topic/411915-gears-hard-to-get-in/
Do you have both Nismo clutch cylinders or just the Nismo slave + Nissan master?
Also did you know Nismo/Nissan only recommend the Nismo clutch cylinders for single plate clutches? (they go to the effort on a Nismo coppermix to say to not use Nismo cylinders)
2 possible causes there.
1. Not enough disengagement of the clutch.
2. Horrible mixture of transmission lubes leading to synchro wierdness. Why did you mix shockproof with MT90?
Heres my thinking; shockproof protect synchro, so I will add some LIGHT shockproof to the mix in order to protect our fragile synchro. I heard other people doing it. Maybe I was wrong.
Suck to waste 50$ of fluid but i've made bigger mistake in the past so I wont be mad about it.
Redline told me to try the car in reverse, if it feel correct, it means the clutch is disengaging correctly. does that make sens?
Edited by cobrAA
I have nismo slave and oem nissan master. dont think nismo make a nismo master anyways?
This stand correct for the COPPERMIX and nismo twins. but it doesnt stand for any other twin and or triple plate clutch on the market. Nismo use a different types of material for their clutch.
There is no synchro in reverse so this is why they will be telling you to try this
Regardless of what the problem is, drop the oil and put redline lightweight ONLY in the box. I don't like the idea of mixing oils
Probably right there, I could have sworn there was a nismo master.
Quoting from: http://www.nismo.co.jp/en/products/competition/clutch/pdf/clutch09.pdf
"Coppermix and non-asbestos clutch discs are equipped with cushion plates and should not be used with the big operating cylinder."
I don't know if the OS Giken falls into the above, but I have read other people use non-Nismo twins/triples and have issues with stroke (clutch engagement being too short) with the Nismo slave.
I'm not a fan of mixing gear oils either, I've never once read anyone on here mixing shockproof with another gear oil. It's always straight shockproof.
I asked Osgiken tech support about the nismo slave and they said it was perfectly fine. I can also admit it really make the pedal a lot softer which I appreciate. (or maybe my oem was giving up). But I know my mecanic told me he had a problem with the slave, the rod was too short I think, so he had to take the rod on my OEM and swap it with the one on the nismo slave. maybe the problem is here ?
I guess I will start by putting only MT90. ( this is what tech support at redline told me to do).
BTW, when I took the car to the gym I tried to play with the clutch and noticed that I could make the gears grind in second while downshifting from 3 to 2. It felt like when you accelerate too quickly and you didn't release completely the clutch pedal but I'm sure my clutch pedal was fully on the floor meaning I clearly have a disengaging issues.
Edited by cobrAA
Do you know how to rev match a down shift? After a certain point (in terms of gearbox loading and/or age) it becomes pretty much a necessity.
box and synchro have been rebuilt in a shop 2 years ago. never rev-matched my car.
Osgiken recommend to cut 4 mm off the center plate or the shaft .. my mechanic didn't do it. This might be the cause. However he can't see how this could change anything so before that I'm thinking about having him installed my old oem slave . if this ever resolve the problem, I'm worried about how the pedal will feel.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
