Come and get this cr@p it's taking up space!
R32 and R33 Gtr and Gtst hubs, subframes, steering racks and more.
Valley Heights Sydney, pick up preferred
R32 Gtst front strut brace, brand new $40
R32 Gtst hicas lock (with rack and rod ends) $50
R32 Gtst front hubs $50
R32 Gtr rear subframe $50 (also have a front subframe $50)
R32 Gtr front hubs (uprights included) $50
R33 Gtst rear subframe with steering rack (has one bent tie rod end) $50
R33 gtst front hubs $50
R33 Gtst front steering rack $50
R33 Gtr rear hubs $50
R33 Gtr front hubs (includes uprights) $50
R33 Gtr front and rear steering racks $50 each
Hi Fatz
I will buy the R33 GTR rear hubs and R33 GTS-T steering rack if they are still available. I will try and pick them up on the weekend - I will give you a call to arrange a time.
Hi Fatz
I just realised that the Nationals in Goulburn are only two weeks away and my car is nothing like ready (new GTR cradle nearly built and ready to be installed, coilovers to be assembled and installed and new brakes to go on) so I will have to do a raincheck on the R33 steering rack.
If you still have it after the Nationals then I will arrange to come and pick it up.
  • 1 month later...
  • 3 weeks later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
