In the process of changing over my turbo's, got the rear one all hooked up and ready to go.
Starting putting together the front turbo, but the oil hose/line doesn't sit nicely and you can't get the hose on that goes to the block.
Anybody else had trouble with this?
See Pic to help with my crap ass description.
Hooks up to the bottom of the turbo, then a rubber hose goes to the engine (sump to drain back the oil)
Edited by Booki
I think drilling out the wholes would effect the seal, Had a attempt and bending it with a blow torch, wouldn't budge. ended up warping it a bit...
So you got those eBay links handy..?
It's a tough little piece of pipe.
If i did that, not sure if i would damage the seal from the base to the pipe, or if it would snap :\
Might just buy one from GCG/eBay, pending if i can get one local or not.
Tunes booked in on the 5th of November, so gotta get this puppy back together asap.
You should piss it in. It's only a 8-10 hour job total
What did you end up doing?
Modified the stock drain which was a big headache as it kept pissing oil, after the 3rd fitting it finally stopped leaking oil, really should have brought the aftermarket drain from GCG though
Just ended up replacing the bolt on the turbo with one with a smaller head so it gave me clearance for the pipe.
Just walked into Rotomaster and somerton, the fella their smoothed out the base of the pipe and provided me some gaskets and the bolt for free! Champion!!
But now ive almost got it all back together, But wondering what the hell is this ground for?
Clip then it goes to a ring connector, sorry for the shitty pic. Any idea's? Looks like a ground for something :\
Also, do people bother putting on the turbo support/braces back on? It looked like such a C*&T to fit so i didn't bother wacking it back on. The turbo's are rock solid and held firmly in place from the Dump/frontpipe and the exhaust manifolds. I doubt the turbo support brace really did anything.
Edited by Booki
Sweet ground strap should be no problem to hook back on with everything back on, (im hoping). does anyone actually know what its for/does?
Hmmm, would you say its important to strip everything out of the way for those braces? Ill have another sticky tomorrow to see if i can get it on. What would you do in my situation scotty?
Also - Draining the engine oil and gonna put some coolant in and start it up for the first time !!
Anybody recommend a particular type of coolant? Or just throw in what ever?
Edited by Booki
I assume the ground strap is to stop corrosion, I usually remove them as they get in the way.
The braces I would be fitting back in place, I know they are a pain but they are there for a good reason, especially if you plan to dyno/track it. The one time I fitted 32GTR turbos for someone, the shitty old stockers I was asked to install back in had stripped threads which made the braces useless.
Don't mix coolants, especially if you have an alloy radiator. Give it a good flush with plain water first then drop it again.
Stock Radiator, So just grab some premix coolants? Is that what you meant? I honestly have no idea what coolant was used prior, this will be my first coolant change in my GTR.
Will have to have a good look underneath and see if i can get the brace back on.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
