parting out 33 gtst track car. Lots of aftermarket suspension bits plus stock stuff.
All items are in excellent or better condition ( some as new)
Parts are located in ipswich qld, I can be contacted on 0413863207 or via pm.
Payment is via postal money order only or cash on pickup (no bank transfer or paypal)
Will gladly refund payment if items are not as described.
1.....Coilovers HSD in great condition, No leaks or knocks......$650.00
2.....Tuneagent front castor rods and rear traction rods....$200 the lot or $100.00 each
3.....Cusco front camber arms in as new condition, top shelf product....$300.00
4.....Rear camber arms tuneagent in excellent nick, spherical bearings are tight as new...$100.00
5.....Full surge tank setup including walbro in tank pump, bosch 044 external pump, custom tank and mounting combo, all wiring relays etc, full setup ready to plug and play....$400.00
6.....Nismo fmic to suit gtst....Including mounting brackets to bolt straight to a 33 gtst without cutting the reo bar.....$200.00
7.....Walbro internal fuel pump...... part no. efp324, as brand new used for 5 minutes only as I thought mine was munted.....$100.00
8.....Headlights series 1....The best pair I have seen in a long while.....$350.00
9.....LCA's..... great condition, tight ball joints $100.00 the pair
10.....Intrument cluster....158 kay the clearest most scratch free cluster you will ever see...$150.00
11.....Braided brake lines....Brake quip braided brake lines in great shape.....$125.00
12.....Nismo fuel cap cover....A rare bird indeed, genuine nismo cap cover that grub screws over your original fuel cap....$50.00
13.....Brakes.... Full set of 33 gtst brakes with dba 4000 rotors front and rear and bendix ultimate pads with 80% meat on the pads. Good buying at %600.00
14.....Kaaz 1.5 way diff....In housing ready to go, great condition....$750.00
15.....Hicas lock bar....., Chrome bar with toe rod ends in place ready to drop straight in....$50.00
16.....Engine loom, ecu, ignitor and coil pack loom,...Will sell as a complete set for $250.00 or will seperate. contact me for pricing
Parts without pics.
Power steering pump, great condition...$100.00
Radiator....good nick....$75.00
Starter motor...Good condition...$100.00
Drivers door switch...good condition....$125.00
Window motors....Goood condition...$100.00 each
Tailshaft...complete in good condition....$150.00
Front reo bar... Unraped uncut in vgc....$250.00
Complete rear hub ssembly with all handbrake parts....left and right in good nick $250.00
Larger items are pickup but happy to post most bits.
Parts pictured below for gtr
Bovs on gtr pipe in great shape....$150.00
Greddy fuel rail in good condition with screw in fittings...$125.00
Catch can....$40.00
33 Gtr dash surround in great shape, no crack etc. $75.00
    • Hi everyone, I have purchased my first GTR and I want to do a single turbo conversion to it. I've been doing as much research as i can and there are a few things that I can find and need to know. I need to run a coolant feed, coolant return, oil feed and oil return for my turbo setup. Here's what I know so far: On the hot side of the rb26 there is coolant feed, oil feed and oil return. Coolant return will be going around the front of the engine to where the thermostat is located. I will need to block off the rear oil return port. I will be running a turbosmart boost solenoid so any of the factory boost stuff wont be needed. Now onto what I don't know: 1. What do I do with the coolant / vacuum hardlines that run around the back of the motor?. 2. What do I block off or loop or move or remove?. I will be running the OEM intake manifold. 3. Is there anything in particular I need to buy for the cold side of the rb26?. I already have the intercooler and pipes sorted. If you have any pictures or information it would be appreciated. Thanks....
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
