  • 1 month later...
Hello hope all is safe and well I have just bought a Nissan Gloria gt ultima but the owners manual is all in Japanese and I am looking for some help to get it in English can anyone please help thanks ?
My email is
[email protected]
Edited by Tracey76
  • 7 months later...
  • 5 months later...
On 6/2/2021 at 11:19 AM, Cheeca99 said:
Hello!! 2000 Nissan Gloria Y34 here! Would you be able to send me the manual and all other docs/information you have regarding the Gloria Y34? My email is: [email protected]
thank you!
On 6/3/2021 at 5:01 PM, bahadir korkmaz said:
hi.I would appreciate it if you could send me all the manuals.nissan cedric hy34 vq30det  1999 ... e post: [email protected]    ...thanks in advance
I'm not going to be sending any more emails. see 3 posts above where everything is on google drive.
  • 6 months later...
  • 7 months later...
Not sure if anyone uses this anymore but my 1999 Gloria has an issue with the whole head unit. It plays cds and the ac works but none of the buttons work on it. Every once in a while the buttons will come on and everything will work but then the next day the buttons don’t work again but the cd will still play and the ac will still blow but I have no control. If anyone knows what the problem is please help!!!
  • 3 months later...
I was sold an engine wiring loom (half intact half cut) from a Gloria with an RB25DET Neo allegedly. I have spent close to two weeks trying to trace all the wiring while looking at THREE different wiring diagrams but neither matches. This loom has completely different colored wiring and I cannot match it 100% to a standard Skyline loom. Is there a database with wiring schematics for all versions of Glorias with a 25DET? The one I have does include Y34 RB25DET schematics but like I said, the wire colors are completely different on every single terminal, sensor and solenoid. I'm going insane. There are especially two 8 pin connectors (black and gray) coming off the same harness near where the ABS module is meant to be and they have both been cut. I think one powers the wipers but unsure.
have you tried comparing with stagea wiring diagrams? C34s specifically. similar drivetrains, same gearboxes, motors, AWD etc.
Not much english info on those RB25 versions, mostly in Russia. Try russian forums.
  • 11 months later...
On 12/9/2022 at 4:04 PM, Leroy Peterson said:
What do you want to know?
Was looking for the radio pinout and climate control pinouts to do some repairs. but i think im screwed haha. ive found a factory shop manual for it but obv it is japanese but i may be able to google translate my way through it when it arrives.
    • So I put it to 3bar (43.5psi) while priming. It stays at 43.5~ as I crank shakes slightly. Ive also tried dropping pressure to see if that changes anything. I replaced the fuel dampener because I was troubleshooting the system along with the stock FPR (swapping them one by one to rule them out). But i only got up to changing the dampener and it started running again. Injectors are stock second hand. I did a bench test on both my original ones and the secondhand ones. The second hand injectors I have in the car now spray slightly stronger than my original injectors.
    • I knew Andy from about then, it did some cool stuff. By 2005/2006 era, he also implemented closed loop ignition timing tuning. In 2004 it was pretty cool, being with him when he was doing automated fast self learning tuning!
    • Im No tuner but…. im running a 25det with north of 600wkw at 9000rpm e85 and water meth. G40 1150 on 32psi. Having a real built head will flow a crap ton more power but you being stuck at 7600 won’t be helping at all, throw all the boost you can and nothing will happen. Solid lifter and 9000rpm is the only way,  I have built my motor 3 times, not from engine failure but more along the lines of my failures in not understanding engine parts better, basic phrase to help, “block hold power”  “head make power”
    • What's the fuel pressure while the car is cranking? Curious, why did you replace the fuel damper? What injectors are you using, are they brand new?
    • I think it's terrible value, it should be half that price IMO. And I'm known as someone who will unironically suggest the GTIII-SS on the RB26 if you have very specific requirements. The GCG RB25DET "hybrid turbo" is 1/3rd the cost of this GTIII-RS kit and sounds like it should fit with zero modifications. Talk to Hypergear as well, maybe they can do something that fits your requirements.
