Hi everyone, looking for a R32 or R33 GTR chassis/shell can be bare shell, needs to be complied and registerable.
Looking for straight chassis preferably with no damage, not fussed about bumpers or anything, does not need to be rolling, no interior or dash required. Basically need a donor car to put my interior and running gear into.
Located in Vic, but will travel for the right one.
https://www.sau.com.au/forums/topic/412785-gtr-chassis-bare-shell/
i have a 33 GT-R however it has some damage front right chassis rail, and bog on real left quarter - would be fine to race though
repair of front chassis rail wouldn't cost a great deal considering the car is now stripped
send me a PM if your interested - has compliance and non VIV so after repair doesn't need to be inspected
I have a R32 GTR minus and engine/gearbox and seats.
Every other part is still there including all looms, interior, aircon, suspension etc
It was registered a few years ago in my name but decided to part it out as I never drove it.
Would rather sell it as is but would sell the shell seperate if you want it quickly and not going to mess me around.
I'll let it go cheap to get my shed space back.
$3500 as is for the lot minus wheels and brakes. You can sell what you don't want to make it cheaper.
Or bare shell $2500 stripped out with only hanging panels.
Where are you located Gareth? Can you send me pics of the car 0439990557 or email them to me please [email protected] Also it is rolling at the moment?
have one if Rowdy's doesnt work out, 3000 shell only $5k shell + panels Could do a deal on a R324 style kit with Xenon lights (Extra 3k), located Mornington Peninsula Victoria
most parts available..
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
