Physical activity morning and night > fitness, improves sleep.
If however, a workout > stimulates sexual arousal; tis best to apply romance a bit earlier so that intercourse follows your workout: then you'll sleep like a baby (unless she wants to talk) lol
A pharmacist colleague was given the pharmacy contract at the Sydney Olympics > had to order an extra few hundred gross of condoms for athletes > probably slept better after the extracurricular activity - or of course, masturbation.
https://www.sau.com.au/forums/topic/412794-sleeping/page/3/#findComment-6773891
I've been trying melatonin for the last week because sleep has been terrible. Unfortunately it's due to my environment, bad bed, noisy trams and traffic through closes windows and blinds that don't fully black out the room. As a full time student I'm mot in the position to change these things. I'm a super light sleeper so it affects me quite a bit. I wear ear plugs. Melatonin makes a difference but I'm not sure if it's completely good yet. Until you're over 50 you shouldn't require as much as the minimum pill size. Infact you could require even less than a quarter pill which is what I'm on. It's good and puts me to sleep but I find I am a little but groggy sometimes in the morning and never feel fully refreshed. I f**king long for those times when I could sleep in until 12 and feel like kicking arse, now I'm just constantly drinking coffee with no effect and getting cranky.
Will continue to try is as its better than nothing but I hope I catch up soon. Not much else I can do :/
https://www.sau.com.au/forums/topic/412794-sleeping/page/3/#findComment-6776534
Oh hahahahahaha honestly dude! Trust me I wish I was a guy so I could just do that but no... I'm a f**king female... So I have naps in the afternoon today like a grandma and went I don't I get grumpy :(
https://www.sau.com.au/forums/topic/412794-sleeping/page/3/#findComment-6776690
Yeah I get you're female.. that's why I suggested female options.. lol.
try it.. you'll sleep better.
https://www.sau.com.au/forums/topic/412794-sleeping/page/3/#findComment-6776721
I know you know I'm female doofus, I was saying I wish I was male so that I actually could be bothered doing that. As a charlie retard female eating chocolate is more enjoyable. So female options are not an option lol
https://www.sau.com.au/forums/topic/412794-sleeping/page/3/#findComment-6776891
flicked your bean and passed out for 3 hours hey?
feel refreshed?
I'm surprised you're suggesting masturbation in lieu of your usual remedy. As far as I know, females have the democratic right to squat.
https://www.sau.com.au/forums/topic/412794-sleeping/page/3/#findComment-6777153
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
