got a few parts left over kicking about, as follows below
pics on request
r32 aircon compressor n mount $80
r32 a/c condensor and most lines $100
r32 gtst metal fuel tank $100
r32 gtr/gts4 atessa....sp? reservoir and lines $40
r33 hicas unit $50
r32 gtr rear sway bar $100
rb20/25 push type excedy heavy duty button clutch $500
near new 500-1000kms
3" split dump/front all in one with $50 worth of heat wrap $150
located VIC -SE
pm or post
Edited by Dan_J
good condition i presume, was removed from a wreck, not due to being faulty
also added
gtr/gts4 manual gearbox cross member and mount $80
rb20 auto tranny Free
might be the 5psd as it came out of a cefiro
s13 sr20 auto tranny free
bump
clutch kit set me back $670 few months back
pics on request
also got
rear s13/r32 JIC coilovers -$150
height adjustable not damper with helper springs, one is leaking
  • 3 weeks later...
  • 2 months later...
  • 1 month later...
  • 4 weeks later...
  • 1 month later...
10 AN turbo oil drain fitting from kando - $40 ------ $50 posted Aus wide
, awhile back bought the wrong one so got this laying around.
suit high mounted turbo or similar with stock oil drain bolt / hypergear.
from the thread start to end its 36cm, 32cm not including the thread on the nut thats crimped onto the braided line
you need to get an adapter to bolt onto the block to 10an
look like this but longer and no barb ( do have one to suit if needed tho)
$%28KGrHqZ,!qgE-y+Ppm%29yBPy+-ElHYw~~60_
  • 1 month later...
  • 1 month later...
  • 3 weeks later...
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
