My Thoughts are....
Its about damn fkn time!!!
im so sick of the current ICE models atm with laggy ass screens and touchscreens that dont work properly or even some decent gui layouts.
The sizing is really close to normal double dinn standard .
Only a matter of time before adapters get made for mass markets.
Im keen to fit one in the GTT.
Thoughts?
https://www.sau.com.au/forums/topic/413143-ipad-mini-in-car-entertainment/
I like it.
Chris, could you set something up.
-audio express
I already have generic fibreglass mounts available , carbon is a well
Ipad full size fit in gtt fine
Ipad minis even easier
with factory look
where the hell would u fit the normal ipads on the gtt? i think itll be abit overkill D:
if someone makes ipad mini mounts for the gtt , ill buy it... for sure
The ipad 2 fits just fine in stock radio location with customization ( perm mount) you could make it slide out near drivers legs without drama , not graceful but doable, I have a spare dash and have tested it already
The mini would pop right in with minimal fuss
Dont have a mini or i would build one
The mini would fit in popup dash as well
Edited by Carbon 34
wonder if its possible to grab a ipad mini model version , like ones of those fakie mobile phones
I know doug and the other guys in the video , they will have generic ipad mini pans for sale and would send one down if anyone wants one?
ipad mini isnt on my radar since ipad fits in gtt and has a bigger screen ,
its not a big deal to mold one , just takes time and a mini to use?? it would fit older skylines ??
for those wondering the ipad fits in the factory radio hole behind the factory dash contour and butts up to the ac controls fine
Some shifter surround mods and remolding but in my case I cut out the ashtray and lighter and ripped apart and recast 3 gauges flush fit in the spot instead
In carbon lol
No need for smoking items
tbh, i think having the original ipad would be a lil bit overkill n i'd prefer to keep the stock smokers try n kit just to keep it looking original n flush.
just my opinion , retina display would be madness tho =D
got any pics of ur finished product with the normal ipad mould?
These guys did a mini within 2 hrs of release!
http://www.macrumors.com/2012/11/02/ipad-mini-already-installed-in-car-dashboard/
The sell all the parts you need to DIY also, incl the moulded pans etc.
I dont have the ipad dash in my car its mocked up on the bench , i have thought about popping it in my car but my current setup rebuild plans would need tweeking , it would be a downgrade on some cases
I do have some mock up photos on my laptop i think showing the process to refinish the dash etc
lots of build log photos etc just havent had time to publish it
you could keep the ashtray etc just i'm a serious hater of smokers lol
Bought a smoke free car from japan which is a miracle to find lol
Sure chris I'll dig up some photos of fitment on the bench think the car test fit ones are still on the camera
The parts are all over ebay same ones as the phone uses ???
Those guys had it in 2 hrs not a big deal if you know what your doing its as fast as the resin dries speed wise? but i would prefer to think it out and make it perfect not a wart on the dash
  • 1 month later...
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
