Are you going to research which turbo would suit or are you happy with whatever they slap on there?
I guess you don't have many choices when it comes to kits. Why don't you do it properly and go custom? GTX3076 FTW. ;)
https://www.sau.com.au/forums/topic/413170-turbo-charging/#findComment-6613056
Im on the fence, ive been quoted 15k through a renowned garage in brisbane for a TT setup after 2 hours discussing options etc and bringing in my tonne of research, Ive been recommended to ERD and GT Auto. Supercharger slightly less figures (especially if you can gather the courage to install yourself), running kits around the 5-7k mark, labour, tuning (been told the Haltech Plat Pro). However, I know of a couple blokes whose engines gave out on the SC not long after, guess the VQ is a give or take on FI :S Let us know how it goes mate
https://www.sau.com.au/forums/topic/413170-turbo-charging/#findComment-6613790
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
