Big Brake Group Buy - Skyline / Silvia / Stagea / Wrx / Evo / All Makes/models
  • Replies 143
For all of those wondering about caliper clearance, I just did a little measuring and while these are not 100% perfectly precise (due to me being unable to measure the D2 while mounted on the car, just dummied up on the bench) - so they're give or take a a millimetre or so
Factory BNR32 GT-R caliper protrudes approx 40mm past the disk mounting face where the wheel bolts up
Factory BCNR33 GT-R/34/V-Spec BNR32 Brembo caliper protrudes approx 40mm past the disk mounting face where the wheel bolts up
The D2 8 Piston caliper with 356mm disk protrudes approx 33mm past the disk mounting face where the wheel bolts up
This means that purely from the point of view of clearance to the back of the spokes, with the D2 you actually gain around 7mm of clearance.
Now the only complication that we bring into the equation is that these calipers will sit out further from the hub than the stock ones, so if your spokes taper back in aggressively, close to your stock calipers than this will reduce the clearance available. Very few wheels do this. So long story short - if you have 18" rims and they clear your factory brakes, be it Brembo or sumitomo 4 pots, you can be reasonably sure they will go over these brakes :)
And the reason there is more clearance for the D2 calipers compared to stock, even though they are physically much larger over all is because the materials used in the construction of the D2 are superior and able to provided the stiffness required to prevent caliper flex, while using less material. Stock calipers are a cast construction and require a lot more bulk to provide the same level of stiffness.
Still can't believe more people have snapped this group buy up!! Need some more people so we can get the first sets out. Next years track days are approaching quick.
Once we have 10 sets - will get those sorted out.
So ONE MORE, and you guys will have presents sometime late Jan most likely - tell your friends! :D
Ok let's get this thing moving, nismoid put me down for a rear kit as well, I've come out under budget this month so I've got more play money :D, rear kit 96 R33 GTST, street pads and yellow calipers please.
Cheers
Excellente!
I'll PM people later tonight with further information and what not (in the PM we already have going) :)
One other guy onboard to - will update and PM everyone with acc info about 10-11pm tonight!!!
So get the EFT's in fast, and we can hopefully get the order sorted before xmas :merli:
If you are last min and want in for this shipment, post here ASAP
PM's with more info sent to everyone.
Last chance to get in on the first run before the order is hopefully put through on Fri :)
Hey mate,
Looking at some black-anodized D2 front calipers. Going by what I've read above seems 330mm for 17" rims or 356mm for 18", this correct? Have an R32 GTS-t so not sure on what the details required would be - but definitely interested.
EDIT - remove. Just realised the date of last response was on the 19th December - apologies.
Does anyone know if work xd9's in 18x10 +18 will clear the 356mm kits on a 32 gtr?
grab a ruler and check it with info Aaron has posted previously if u have stock brakes at the mo
I'm running similar spec rims and going with 356 kit
Cheers mate would love to measure it but i havent bought the wheels yet, lol
Got 17's on there at the moment but they will have to go as soon as i get the new brakes.
Hey Mate
can tell you 100% the XD9 in 18 x 10" +18 will clear the brakes, or I'll refund you no probs. They have loads of brake clearance :)
Cheers
Aaron
Hey Mate,
you're spot on. the 356mm ones need 18" min, the 330mm will go sweet under 17"s
The second round of this group buy will be cranking up very shortly I believe, so you are not too late if you want to jump on board :)
Cheers
Aaron
Hey mate,
Hey Mate
Cheers
Aaron
Thanks Aaron, looks like ill be ordering the wheels now then.
Confirmed the order has been placed after talking with Aaron @ Import Monster
I've started a thread for the 2nd Round as I'm getting PM's from people asking if it's closed, so see here if you want in on ROUND 2:
http://www.skylinesaustralia.com/forums/topic/417253-big-brake-group-buy-2-skyline-silvia-stagea-wrx-evo-all-makesmodels/
Update is above mate, that was 10 days ago. Order placed, waiting for completion and shipping (order was placed days before i posted, just had no internet to update over NYE period).
Once i know more, I will post for everyone. It does take a few weeks for the orders to fill. :)
Yep order was submitted to D2 in the first week of Jan, after they returned from their New Year holidays. From experience, it usually takes around 2-3 weeks for them to complete an order of this size and then around the same again to get shipped, clear customs and quarantine and land in the shop. I'll keep Ash updated as we reach each step :)
Hey Guys,
just an update, manufacture of the kits will finish this week and the freight has been booked. The ETA for the ship to arrive is approx 13/02 and it would usually take 3-4 days to clear from port and customs and arrive to our shop.
Cheers
Aaron
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
