  • Replies 54
First skyline was stolen and put up a gutter (financial write-off) 3 months after I bought it.
Second skyline has had many issues after engine mods, as well as being defected for missing front number plate which resulted in engineer's cert being required for mods as well as a myriad of other shit being fixed. $2700 to get it back on the road.
Plenty of details in the engine mod issues to make it seem much worse, but you get the idea.
So ive had the GTR back for... 1 week. And one of the turbos just went. Back in it goes.... May not make SAU nationals now =(
I hope there not the old ceramic turbs and if it is I hope there is no dust/pieces in your block
Touch wood !!
All the Tears, Sweat and Blood I hope mine will be fine for the next 20+ years
Pulls hard like a teenage boy and feels strong as an Ox
If you like we can swap 32's?
though after these turbos are done i hope mine never breaks again.... hope....
In saying that its gotta go in for a front end paint job again as well... SIGH
I've had to replace hubs and bearings (hubs for my car are hard to find) then had to replace the bearings on the other side and steering rack ends, then when that was done my windscreen was smashed, as soon as that was replaced the clutch wore out, now its the power steering that's dying. Not to mention the amount of times my window motor has died, im half way through taking it out and it suddenly comes back to life - though at the moment its dead.
Its a curse. has to be.
I guess I have been pretty lucky (touch wood!!). I have owned mine for almost 3 years with only one issue. After about a month of ownership the idler bearing went.
What boost were you making? I intentionally had mine set at 12psi when it was tuned as I cant afford to replace the turbos right now.
I still have the opinion that I've been VERY lucky with my GTR.
Remember a lot of these things you guys are all mentioning is wear and tear on what are getting to be pretty old cars now!
I've had to spend a lot of money on things like suspension and things wearing out.
In terms of breaking besides the block only thing that's ever given way on me was a stock turbo... That was my fault for not leaving well enough alone and letting them boost it to 14psi. Just remember, the more you mess with things and the harder you push them the worse this situation is going to get!!
Saying that really anything could be considered fair wear and tear. Even a block pushed beyond it's design limit.
True. This is a known fault even on fairly unmodified RBs!
The unlucky part was that it had been inspected like 2 months earlier and was perfect. I fully accept that's what happens when you buy an old car particular if you f**k with it like I have :)
Supra written off while waiting at a give way sign
Loan approved sold my soarer loan cancelled by the bank the next day no car
14k 180 paid off over 11months only worked for 3weeks
Ca18 180 owned for a week replaced the alternator went for a drive blew both radiator hoses overheated cooked the engine
Sr20 180 finally running after wiring problems went drifting spun the bottom end
Bought the skyline has been crashed three times and still not 1 mechanical fault hahaha
Bought the soarer back fuel pump ecu died indicators died front tire went flat
Hahahah all problems probes my fault so don't think they count as bad luck but hey all part of the import life lol
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
