  • Replies 90
Ive taken next week off work. Ready to go. Only 2 goals for the week. Complete my brake install. And try to prestige within the week. lol
Within a week? You could prestige in a day in Black Ops. You probably get your first prestige level by managing to start the game.
Dag nammit!
http://www.skylinesa...58-black-ops-2/
Looking forward to the zombies; that is all.
Whoops.... lol
Got this yesterday. First game ive bought in years..... usually play my bros :)
its the shit....... Seems to be a glitch in campaign mode - Which is pissing me off - Apart from that. all good
Someone that plays campaign?
I didn't even touch campaign in MW3
I love a good campaign, They have actually put a shitlaod of effort in this one.... Its dam good.
Playing Zombies with the boys last night - Off it tits. Catching the bus from town to town collecting parts ect its mad
They went to a lot of effort with the storyline in the first Black Ops. Was a really enjoyable single player game. Can't wait to get my hands on the new one!
Sitting at lvl 35 now. Trying my best to get hours in but between working on the car and the Wife laying down the law. Then a couple of nights of connection issues. hmm. its a battle.
The Vector absolutely rocks and barely anyone is using it (going by the amount of times i've been killed with it according to Elite). Just prestiged that the 1st time round. 400 odd kills it took.
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
