G'day guys, well ive changed my ****ing mind again so my TD06-20G setup is up for sale
What you get is
2X Kinugawa TD06-20G turbochargers, with surge ported housing
Trust twin T67 manifold, absolute work of art, i may of furiously masturbated to this
Heaps of fittings and **** from kinugawa
2 Genuine trust TD06 heat shields, look pretty
Fatz can vouch for how awesome this is, even though he is a flamin mongrel
Message me on 0434121069
https://www.sau.com.au/forums/topic/413615-trust-twin-rb26-td06-20g-setup-2000/
Sir. After gazing at your curly bits, you are most certainly exhonerated from any liability after yanking yourself over those pipes, they're horn!!
What sort of revs do those fat boys kick in at, 14,000rpm??? When Spool bring out their RB38 stroker kit that they're working on that should bring them in a bit earlier.
Any dyno figures of results?
So do they fit with stock twin turbo pipe and afms? Don't want it to stand out to the boys in blue lol, (joking) absolute work if art is an understatement, what power were u hoping for with this setup?
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
