Hey guys n girls, My engine is out and getting a full rebuild with forged pistons and everything else that goes with a full rebuild.
Remac in gawler are doing alot of it, plus one of my mates at adelaide jap.
What do you think is a rough ballmark figure with labour n parts and everything else that goes with rebuilding an engine from floor up?
Here is my quote.post-91919-0-87174800-1352892210_thumb.jpgpost-91919-0-03951900-1352892239_thumb.jpgpost-91919-0-75209500-1352892265_thumb.jpgpost-91919-0-22005500-1352892292_thumb.jpg
https://www.sau.com.au/forums/topic/413696-rb25det-neo-full-rebuild/
ouch. that's why I do as much work my self as possible. just quickly what power fig you looking for coz with your turbo set up ya got even with e85 your not going to need rods just balance the standard ones save the dollars standard ones in a neo are same. as gtr. ones any way also might of missed it but what head gasket you running ya need a good quality mls head gasket. what happened to your old engine exactly.
What is the total? Couldn't make it out. This looks like a gold plated build - no excuse for failure here!
As above Neo have GTR rods so would be fine unless you are going for super high kw - what is your target? What turbo do you have in mind?
Conventional wisdom among some of the better engine builders on this forum is you don't need to use a torque plate for RB engines.
WARNING - some people including some workshops that should know better use the wrong pistons for the Neo engine and end up with sky - high compression ratio!
Prices look high to me but then most things are cheaper in NZ. - You could have bought an RB30 short bllock from RIPS!
As the saying goes if you can afford it and they do a good job you will forget about the price in time.
Try buing some of the parts yourself and suppling them
CP pistons can be had for under $1000
I can buy chinese made rods like Eagle for $24USD each....$150 set
(I have some brand new Nismo Rb26/25 rods here in the box. Will sell them for less than the eagle rods they have quoted)
thanks for your input people, i would have no idea how to pull out an engine and put one back in, look at all that wiring. purchased a n1 oil pump today. Once i get my engine back and ran in ima grab a walbro 400lph fuel pump another turbo capable of 600 hp and gonna get my car tuned for around 350rwks thats all my z32 afm will allow ive been told.
you will make so close to that with the turbo you got when you run e85. at least 320 no need to buy another turbo. but your auto box is going to be way past its limit annnnd ya going to need a stall converter
FYI that all comes to a smidge under $9,000.
NOT OVER 9000!
As has been said, you can save $500 on rods and the CP piston set seems a little pricey. In fact, even Ebay has eagle rods/CP piston sets for ~$1250 delivered.
http://www.ebay.com.au/itm/CP-Pistons-Eagle-Rods-Skyline-RB25DET-R32-R33-86-5mm-/270771423476?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f0b3c08f4&_uhb=1#ht_4473wt_1163
Hang on...
'FIT PISTONS AND RODS: $245.00'
'REASEMBLE ENGINE: $950.00'
SUM-TING-WONG
In all fairness, if you can't do it yourself or aren't confident, it's a lot to spend BUT if it's built properly, it'll be worth it.
A lot of backyard builders out there who have NFI what they're doing so it's not something you skimp on.
Does it come with warranty?
You would be able to source parts cheaper but some builders won't let you supply parts as they won't warrant it.
Edited by Akshunhiro
what has gone wrong with current engine. don't forget you will also need a Bosch 044 external fuel pump and surge tank. also to achive ethat power fig you would need to fig in pon cams as well. but 9 k is just bloody ridiculous. and don't forget to fig in drive train loss of having an auto to achive 350 you would need to be making nearly 400 on a manual. the thing you need to keep in consideration is the supporting mods you need to make it a reliable car as it is your daily driver. I could ring more out of mine but I know I would be leaning on my box(bit worn) and drive line. and also don't forget braking upgrades you will need them . shoot me a pm might be able to help you with some stuff
cheers jase
$9000 (plus some unbudgetted extras) is a lot of money but not a rip off if the result is excellent.
This guy has a $20k budget (albeit for a GTR) http://www.skylinesaustralia.com/forums/topic/413703-20k-for-newrebuilt-engine-options/
lol I've spent under 21k on my whole car. including neo engine swap manual conversion cams everything and the actual purchase price of the car and the result is excellent. I save big dollars by reaserch. and then building cars my self . but I understand not everyone is capable of this . I already have a gtr box in mine but remember the result extra weight you are pushing does load them up. does not need a link he has a s2 and runs a nistune and already. runs a 3076 & will run e85 so really a set of forged piston, head gasket, studs, and cams will safely get him close to what he wants on the limit of the auto.
My radiator tank on the top cracked, car overheated and i ended up hurting a couple of cylinders. Plus the head gasket went. I got no choice really but to do this sort of build, i have also purchased a cooling pro full alluminium radiator so this wont happen again. Im looking forward to a bullet proof engine.
i'd be cautious using a new n1 pump
seems the new ones are pretty random build quality
i also remember someone saying that maybe the neo got a better pump
make sure they use the right restrictors in the head too, neo head has solid lifters so it doesn't need as much oil apparently (compared to r33 rb25)
really it is quite possible to replace engine with another standard neo stag engine chuck in a head gasket and it should behappy making over 300 have a look at the unopened 300kw club on this forum. save $$$$. I've seen so many ppl in my years in the modified car scene spend thousands and thousands of dollars by and years later still have a unfinished project that's made no power., hello truth be known I've done it my self in my younger years.
also with the auto M.Vs do a billet servo to strengthen there boxes (jet r31 has one in his stag) have a chat to mike @ mvs also like I said sus out a small stall converter
Already have the billet piece put in, would love a stall converter tho. What a rough price on one of them installed?
If you are in Adelaide you're in luck - MV autos 1 Stirling Rd Blackwood are the experts - give Mike a ring.
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
