Need to sell my C33 Laurel asap as im needing the funds for my new car.
This is my very first car.
Bought as a stocker RB20E.
1989 C33 laurel
- RB25DET S2 out of a 96 R33. (ks now unknown but was put in under 100,XXX)
- 5Spd manual RB25 Box
- ISC coilovers all round
- Upgraded R33 front brakes
- One piece tail shaft
- FMIC
- 3" exhaust from dump pipe back
- GKtech Dumpipe
- Front strut brace
- Modplated for engine and transmission conversion.
- Blitz S-spec EBC
-Turbo timer (not fitted)
Bad points:
- Car has a dent in the bottom of the LHF door, got hit by a neighbour.
- Small rust spot starting to form on the LH C-pillar.
- Starter motor is starting to become sticky.
- Needs some front tyres, rears are brand new.
The car had a boost problem for ages where I couldnt boost past 2-3 psi without hesitation. Found out it was due to a ruptured fuel line from the pump to the pump cradle. Drove fine off boost so it was driven of boost for most of the time until i could figure out the problem. Runs so much better and can now see 10 psi which is what it is set too.
Car hasn't been drifted or done burnouts, NO LSD.
The 25 is healthy as still no leaks or knocks
Contact: Iain - 0422022887
Some vids of the car
Idling
Quick drive
new pwr steer pump
new handbrake cable
wiper blades
roadworthy front tyres.
everything else is sweet.
No engine leaks
fmic is secure
pod filter is secure
suspension doesnt leak
