Need to sell my C33 Laurel asap as im needing the funds for my new car.
This is my very first car.
Bought as a stocker RB20E.
1989 C33 laurel
- RB25DET S2 out of a 96 R33. (ks now unknown but was put in under 100,XXX)
- 5Spd manual RB25 Box
- ISC coilovers all round
- Upgraded R33 front brakes
- One piece tail shaft
- FMIC
- 3" exhaust from dump pipe back
- GKtech Dumpipe
- Front strut brace
- Modplated for engine and transmission conversion.
- Blitz S-spec EBC
-Turbo timer (not fitted)
Bad points:
- Car has a dent in the bottom of the LHF door, got hit by a neighbour.
- Small rust spot starting to form on the LH C-pillar.
- Starter motor is starting to become sticky.
- Needs some front tyres, rears are brand new.
The car had a boost problem for ages where I couldnt boost past 2-3 psi without hesitation. Found out it was due to a ruptured fuel line from the pump to the pump cradle. Drove fine off boost so it was driven of boost for most of the time until i could figure out the problem. Runs so much better and can now see 10 psi which is what it is set too.
Car hasn't been drifted or done burnouts, NO LSD.
The 25 is healthy as still no leaks or knocks
Contact: Iain - 0422022887
Some vids of the car
Idling
Quick drive
new pwr steer pump
new handbrake cable
wiper blades
roadworthy front tyres.
everything else is sweet.
No engine leaks
fmic is secure
pod filter is secure
suspension doesnt leak
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
