I would like to increase the strength of my power steering in my r32 coupe.
Anyone have any ideas on how I might do this? Anyone done this?
It would be nice to be able to more easily control the wheel with one hand while the other is on the shifter while course correcting etc. My daily lancer has great power steering!
https://www.sau.com.au/forums/topic/413860-r32-power-steering-modifications/
I've locked out the HICAS, looped the power steering lines to the rear solenoid which greatly improved the power steering feel, but was wondering if there was more I could do to improve the feel.
Or .. maybe I have an electrical problem .. any ideas on how to diagnose where the issue might be?
Out of all the cars I've owned or driven, my R32 GTR's powersteering is the lightest, infact so light I could control it with my thumb and index finger. There is definitely a problem with your PS.
List of things to check: Low fluid levels, slipping or missing PS belt, underdriven PS pulley, steering wheel taken off (aftermarket or standard) and not aligned dead centre when put back on etc
locking out the hicas wouldnt of made a difference except for maybe a placebo effect, i got my 32 with the hicas removed, i refitted it and the front steering felt no different
Thanks everyone for the responses
fluid levels are fine
PS belt is there, but squeaks sometimes
stock steering wheel - no mods
would getting a larger PS pulley (and overdriving it) damage anything at all?
Should I install a non-hicas PS pump instead?
Thanks everyone
Larger pulley will underdrive the pump.
Non HICAS pump only differs in not having a rear pump stage. I would try to find an R33 one anyway, just to get rid of the annoying loop. Oh, and fit a proper PS cooler in place of the original cooling loop.
But I wouldn't expect any of that to help your problem.
would running wide rims with stretched tyres cause the steering to be heavier? i.e. 9.5" all round? i have the hicas removed also and find the steering a tad heavy but then again i don't mind an extra workout and the steering feedback is always welcome I wouldn't describe it as light though compared to my MY11 Rexy
  • 10 months later...
old topic but incase anyone else is after the solition in the future.
the problem is the solenoid on the front steering rack. this is controlled by the hicas computer to make the steering really easy at low speed and a bit harder at hi speed 80km+ (when you wouldnt notice the harder steering) When people muck around with the hicas + the 32s getting old these days the hicas computer (located under the rear pacel shelf btw) tells the solenoid to make the steering harder by bypassing power steering flud in the rack sometimes when the car is below 80km which gives it a heavy feel, but not as heavy as no power steering, which is why people often get confused what the hell is going on.
the solution! take the solenoid off the front steering rack (3 bolts maybe?), trace the shape out on bit of metal plate, cut out the same shape and simply bolt on a metal plate in its place. Light power steering all the time!
  • Like 1
Does anyone have any photos of which solenoid needs to removed? Thanks! - also why would a metal plate need to be installed to replace said solenoid once removed?
Photos? Really? Open bonnet. Look at steering rack (follow steering column down under plenum). See solenoid. Has wires.
Plate is to stop the PS fluid pissing out when you remove the solenoid.
Mod is a bit unpleasant. R32 could use less assistance, not more. Would not do.
bit more info:
http://forum.r31skylineclub.com/index.php?topic=66472.0
gtsboy your power sterring is obiously working correctly. see so many 32 owners myself included winge about heavy power steering and this is the reason. trust me when the solenoid is active the steering is that hard to the point of believeing you have no power steering at all.
your right though... ghetto as mod
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
