Looking To Borrow Wheels / Tyres To Take My R34 Gtr To Wsid
Hi,
As title states I am looking for someone who is willing to let me borrow their set of wheels (w/ grippy tyres) to take my R34 GTR for her first run down the strip :)
Slicks / Semi's will be prefered and with some luck and sticky tyres I get booted off after 1 run with a 10.xx (unlikely as its my first time attending with her but fingers crossed) :ninja: Either way being an AWD and incapable of frying them before the Christmas tree your tyres will not go through much abuse at all.
Happy to pick the wheels up and drop them off or even change them on at the track and take them back off when I leave if you decide to come past WSID and watch/participate.
In saying that I am ofcourse willing to compensate anyone nice enough to lend me the tyres with $$$ or beer/skotch/strippers/whatever - which ever they prefer :P
Customary picture of car attached below, PM if anyone has any offers :)
Cheers !!
If you can't fry the tyres then doubt you'll get a 10. Also getting a good launch takes a bit more than you might think. Just take your street tyres and run them down to about 28psi.
A 300kw car with an ok launch will run high 11's to low 12's. With a fantastic launch, which takes longer than you might think to muster, 300kw will get you to low-mid 11's. Caveat emptor of course is that torque and area of the power curve is what really affects the variance in times at the same power levels.
Turn your boost controller down and make a few runs. If you are getting 60 ft times of 1.6 or better then you're ready to turn it up.
By fry i implied sitting it on the brakes which I obviously cant do :( she definately has a potential for a high 10 though with sticky tyres based on what I have seen and experienced in the past.
Would take my street tyres down but im running 275's front and back on 19 x 10.5" wheels which are absolutely hopeless for drags
Get some r33 Gtr wheels and decent rubber for future meets.
Ive can get my hands on a spare set of R33 GTR wheels with crap rubber on them however im going for a 10.x in street trim to get booted off and never go back hence cant justify spending >$1000 on wrapping them with good rubber if their only gona see 2 or so passes down the quater (1 on low boost, 1 on high).
Not intending on doing any track days with this car either so tyres/rims will be redundant after the runs down the quater
Don't be a girl, run it with the 19's on.
My wagon ran 12.3 with 19's, 245 rubber and less power.
I'm confident it will get 11s all day every day with stuff all effort even with the 19's.
I'm not after 11s though I'm after a 10. I can't see the point of putting the driveline through unnecessary shock by launching the tits off it with 10.5" 275/35/19 front and back when I know it won't get the desired time I'm after.
I think the best bet is to do what alot of us do and just run on your street tires and prove how fast your car is in a "street trim". Set a base time for the car then next time run it with semi and see how little or no difference the tires make. My GTsT with half your power ran a 14.2 and i was just happy to have a top speed run. If you can drive properly you can avoid unecessary drive train strain no matter what tires you run. Also if your car is street registered and not in super street class you must run a street legal radial tire so some semi/full slicks are not aloud.
I took my 34 out to for the first time a couple of months ago and run on 19's even kept 38psi in them.
285/35/19 Federal RPM's
It's all about going out for fun, my 34 is factory stock standard and the clutch wasn't up for it..
Cheers for the advice mate, might just go and give her a blast and see which end of the 11's scale she comes home to with the rubbish tyres on atm. Definately investing in a set of Micky T's ET Street Radials on the bucket list for Christmas :)
Believe it or not I had a standard clutch holding up ~340awkw at one point and went strong for a good 4-5 months until it finally went pop (quiet literally the pressue plate shattered). Got the Nismo C-spec twin atm and its on a totally different ball game but standard clutch for up to 270kw in my experience was bloody awesome !
Ps how did you go :) ?
I used to have an MX83 Cressida with a 1UZFE V8 conversion and I went out with SAU/V8 Owners day and I was running 15.5 all day long coming off the line at idle on stock tyres and it took me over 3 months of practice to run a 14.709 and I had 156Kw at the wheels, LSD, 245/45 x 16 Toyo TEO Plus road tyres @ 24psi and for this I had the car up onto 2300rpm to come off the line.
It aint so simple as I thought.
I never ran it again after that, just wanted to prove I could do something with it and I was pretty impressed with the look on the face of the HSV driver in the next lane that did a 14.9??
Sold the car on to someone that sorta stuffed it for mine.
Now my newest toy climbs mountains lol
Cheers, D
1st run was 14.1 @ 104mph then clutch just got worse, come back next day for eliminations and went 13.7 @ 90mph.. poor clutch didn't cut it and I pretty much rolled over the line for that pass..
My Nismo Coppermix twin Comp clutch gets put in next week and I'll head back out and see how it goes before swapping out the twins for a new 6262 setup.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
