Hey guys, I posted this on nissansil but i seem to find a lot more people using sau, a lot more mature readers to.
Basically went to get my s15 tuned today, sr20 standard bottom end all the fruit, high mount steam pipe manifold td06sl2 20g 10cm (kando in t2 platform) tial 38mm mvs gate.
Issue is, using a .6 bar spring, as it ramps it's ramping to about 1bar of boost then as it increases from 4grand to red line it boosts to around 18 psi.
My theories are - wastegate size could be to small but from everything i have read, there is no issues using a 38mm wastegate to control 18psi on a turbo of that size (very similar to a 3071r if your not familiar with mitsi ranges)
- wastegate is fingered or fake - did pull it apart, diaphram looks legit and paid quality money for it.
- position of wastegate on manifold isn't getting a decent amount of flow to the actual wastegate
- scrap car and buy an r35 gtr
sorry for the novel, help me sau!
here's a pic of the manifold i got made for an idea of what the gate position is like - doesn't look to bad to me
It should work, ish
Gate pipe positioning is not great, what is the transition like inside the manifold.
Imagaine how hard it is for poor old cylinders 1 and 4 trying to muscle through cylinders 2 and 3 to get out the screamer.
Can you just run 18 PSI? Or run the engine with no gate. I have seen 10 psi doing this on crappy manifolds.
As i'm running an auto I sometimes hit the limiter, so my tuner gave me a soft limit between 7 -7.5k. Every time I hit it my turbo overboosts to over 30psi.
Ethanol is your answer.
First, as other have said primary pipe 90deg to the gas flow is not ideal
Secondly, looks like the primary pipe for the gate is smaller than the v-band and then the screamer pipe is smaller than the v-band?
So while you have a 38mm gate, you are putting a restriction before and after the gate.
I would start by getting a bigger primary pipe and screamer pipe to actually the same size (or slightly larger) than the v-band
Edited by SimonR32
    • Nah that is not actually a lot. Just painting my GTR frontend and the little bits to make sideskirts/nismo flare pieces work correctly/fit on the sedan/mount up correctly came to about $7000. Is it a lot? Sure. None of this is economical. Economy would be shelling the car and buying a 2010 Corolla to commute in. The perspective of all of this is different.
    • I have the re003s’ on my 06 XT Forester Turbo and I highly rate them for street wet and dry
    • I don't see any issues here. I've been saying all along this is a big job, the price reflects that.  When the car comes back perfect I'm sure it will feel like money well spent.
    • Remember, take original quote. Double it. Then add a bit more. It's how any project goes.
    • So, I started this repair and got as far as "fixing" the holes with some fibreglass. God all those years working on boats came back quickly. I decided I'd reach out to some rust guys just to see what they would say about it. I came across a guy about 40 mins away and went to see him. He said the windscreen needs to come out, that there might be some more bits around the windscreen and he'd quote them at the time. But his quote was $300 to remove and replace windscreen and $3k for the damage he can see. He said he could respray the roof for $1200 and the bonnet for another $800 (somebody has previously rattle canned it, its horrendous). This is $5300 + any small additional bits. It's a lot, I get that and the name of one of my fave youtube channels 'Not Economically Viable' comes to mind.  I'm not being financially rational, but I've taken him up on the quote. He's opening a new shop in November with more room, so we're waiting for that. I'll leave the currently missing headliner out until then. I'm looking forward to it being fixed and having the paint looking nice again (lots of clear coat issues on the roof too). / flame suit on.
