Kamui Kobayashi is so determined to remain in Formula One that he has set up a website which he hopes will help raise funds to keep him on the grid.
The 26-year-old, who claimed his maiden F1 podium at his home race at Suzuka this year, has turned to the internet to raise some funds, hoping fans will use www.kamui-support.com to help his cause. Those who make donations will receive special wristbands.
http://www.planetf1.com/driver/18227/8289316/Kamui-hopes-website-can-save-F1-seat
http://www.kamui-support.com/
Massa2013........
if he carries over his current form from the last 6 races of this season, he will be a contender. The Ferrari team mate battle is one of the things i am looking forward to next year. They did suggest if Alonso doesn't win the title, its anything goes..
Momtezemolo was recently quoted as saying something along the lines of Alonso should first win the title if he wants a co-driver not to bother him...
I don't think they will be protecting Alonso at Massa's expense at the start of the season. I reckon they'll wait to see who's ahead as they get to the business end of the year.
Edited by hrd-hr30
I wasn't joking about massa being a contender.
Hamilton will have troubles. So I don't think he will be up there every race. Vettel would be the only one to be up there most of the season. So the rest is a points game, not number of races won unfortunately. Massa has been very consistent in the second half of the season.
It'll be dependent on how Ferrari is early in the season. Anything like this year then it'll be like this year again.
Yeah that is the right answer for the media but if push comes to shove I would prefer to be Nando rather than Nando's Brazilian Bitch.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
