Bruno Senna has walked away from Formula One, signing a deal to race for Aston Martin in this year's World Endurance Championship.
Senna will share the #99 with Fred Makoweicki contesting the full Championship while Rob Bell will join them for the Le Mans 24 Hours and the Spa 6 Hours.
http://www.planetf1....-farewell-to-F1
Marussia have confirmed Luiz Razia as their second driver for 2013.
http://www.planetf1....a-confirm-Razia
Day twoTimes
01. Romain Grosjean Lotus 1m18.218 95 laps
02. Paul di Resta Force India 1m19.003 + 0.785 95 laps
03. Daniel Ricciardo Toro Rosso 1m19.134 + 0.916 83 laps
04. Mark Webber Red Bull 1m19.338 + 1.120 101 laps
05. Nico Hulkenberg Sauber 1m19.502 + 1.284 99 laps
06. Lewis Hamilton Mercedes 1m19.519 + 1.301 15 laps
07. Sergio Perez McLaren 1m19.572 + 1.354 81 laps
08. Felipe Massa Ferrari 1m19.914 + 1.696 78 laps
09. Pastor Maldonado Williams 1m20.693 + 2.475 71 laps
10. James Rossiter Force India 1m21.273 + 3.055 19 laps
11. Giedo van der Garde Caterham 1m21.311 + 3.093 88 laps
12. Luiz Razia Marussia 1m23.537 + 5.319 31 laps
http://www.planetf1....-Way-On-Day-Two
http://www.planetf1....ictures#photo=2
good job mang.
problem solved?
btw.
Lewis Hamilton has billed the brake failure that caused his Jerez crash on Wednesday as "all part of testing."
Hamilton's first official day in his Mercedes W04 came to a premature end when, just after 15 laps, he suffered a rear brake pressure problem.
Although using the front brakes to slow the car, the 28-year-old was not able to prevent a crash, hitting the tyre barrier at the Dry Sack hairpin nose first.
Mercedes later revealed that the problem was caused by a hydraulic brake line connecting to the right-rear calliper.
http://www.planetf1.com/driver/18227/8476009/Hamilton-Better-now-than-later
    • I mean it's a bit late to say "This won't have any tangible effect and it is not worth spending more than about three seconds on it, please just enjoy the car" But I said it anyway. Does the pod actually get any airflow in that position behind a bumper like that?
    • Hey guys - apologies for digging this up. Has this website been shutdown or is the outage temporary?
    • So, went shopping at Just Jap for things that might work for the intake  After some trial fitting there I ended up with a 3" x 45° silicone bend, a 3" x 300mm alloy straight, and a humped joiner, some minor trimming will be required to shorten some of the stuff, but nothing that is beyond my "ham fisted" skills The guy at Just Jap was most helpful as we had all sorts of joiners,  bends and stuff out trial fitting  Laying it out above the stuff in there it seems everything will fit nicely, and looking at it, it is probably the way I should have been looking at doing it from the beginning, probably..... In the end it is a front bar off job anyway to remove the original stuff behind the front bar that is taking up the required realestate needed, so maybe a Thursday or Friday job And because I'm a hopeless consumer, I grabbed some new steel wheel nuts, the current ones are a spline drive type with a "security" socket, that somehow someone keeps misplacing, the new ones are a basic black steel 17mm hex socket In other news: I just did my "final" tax return, I am now officially a old retired veteran pensioner, and I'm milking the system for all it's worth,  life is good
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
