Robert Kubica will make his return to competitive racing later this month after it was confirmed he will race in the WRC2 category of the World Rally Championship.
The FIA has given Citroen permission to use a paddle-shift gearbox on the left side of the steering wheel, with its change of speed to match that of a conventional gearbox.
http://www.planetf1.com/driver/18227/8542021/Kubica-to-race-in-WRC2
Formula One supremo Bernie Ecclestone believes a 22-race calendar is within the realms of possibility and is also eager to have stopover in Cape Town.
http://www.planetf1.com/driver/18227/8541693/Bernie-eyeing-22-races-and-Cape-Town
Drug testers have swooped on the homes of several Formula One drivers, including Australia's Daniel Ricciardo, in surprise early morning raids.
Ferrari's dual world champion Fernando Alonso said the testers, from the World Anti-Doping Agency (WADA), arrived at his house at 6.42am on Tuesday.
New McLaren driver Sergio Perez confirmed he had endured a very early morning wake-up call as the result of a surprise urine test.
And Torro Rosso racer Ricciardo tweeted that he "Got drug tested early hours this morning."
He said: "All of a sudden pissing in your own home becomes difficult with someone staring over your shoulder."
Drug testing in F1 is relatively rare, but it is not the first time officials have made surprise visits to drivers' homes.
In 2009 Mercedes driver Nico Rosberg - then with Williams F1 - was drug-tested by WADA while on holiday in Ibiza.
He said the agent woke him up at 7am one morning, informing him that he had been selected for a random drugs spot-check.
"My girlfriend took the call," Rosberg said. "So it was lucky that the test took place at all because she doesn't like being woken up early while on holiday."
Mark Webber recently called on Formula One's governing body, the FIA, to step up its drug testing, after a motorcycle racer was banned.
Former MotoGP rider Anthony West, who now races in the second-tier Moto2 category, was banned for a month after testing positive for the stimulant Methylhexaneamine.
Webber welcomed motorcycling's push to ensure the sport is drug-free, and called on the FIA to become more active on the issue.
"I've always been championing the idea to do more of it, but the FIA have never really been that strong on it," Webber said.
"The other drivers have never been super strong on it, so it's never really been a huge issue."
Domestically, V8 Supercar drivers will be drug tested up to three times more often under tougher anti-doping rules to be implemented by motor sport authorities, according to a Fairfax report.
Through CAMS, V8 Supercars complies with the anti-doping requirements of WADA and the Australian Sports Anti-Doping Authority.
Racing drivers have not been implicated in the recent Australian Crime Commission's investigation into drugs and corruption in sport but CAMS will review its approach to anti-doping, illicit drugs and also race fixing and corruption.
http://wwos.ninemsn.com.au/article.aspx?id=8621883
So for any of u guys who want to
Go or are on thursday. I have a spare silver gp advantage ticket.... Eg early entry, breaky and a pit walk thing!
If you want to join me and a mate for the tour and breaky let me know
$60 0400099986 to tee it up!
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
