When she kneels down a bit to get to the right height?
A shame Kimi damaged his front wing today. I thought he would challenge for the win today, Grosjean was nowhere in the same car so he needs to get back on the angry pills.
Hamo held it together ok too.
Red Bull’s Mark Webber will drop three places on the grid for next weekend’s 2013 Formula 1 Gulf Air Bahrain Grand Prix after stewards penalised him for his collision with Toro Rosso’s Jean-Eric Vergne in Sunday’s Shanghai race. And Sauber’s Esteban Gutierrez will be demoted five grid places at Sakhir for his crash with Force India’s Adrian Sutil.
“I think Mark could not have got through from where he tried and I’m not even sure if he was trying to pass me,” said Vergne afterwards. “Certainly I didn’t even know he was there.
Chin's fault but surely at this level Vergne should be a little more aware since it is his second season.
Frankly I am glad Webber did what he did. It was a racing incident but as the commentators and Webber dsaid. Vergne seemed to stay wide and then apexed later. Showing a quicker car the inside was a bit silly but was his corner and able to turn in. I think Webber having to pit in a few laps wanted to keep the hammer down and had a punt. Good to see a bit of aggression back in Marks driving...shame it didnt pay off.
Not sure I agree with the 3 spot penalty. It wasnt that much of a botched attempt in light of the line Vergne took. But a weekedn to forget for Webber and will be interesting hwo he bounces back when they first arrive back in Europe. He always goes well and would be a change of fortune if he actually had a good result in Bahrain. I am not holding my breath :(
Massive congrats to Disco Dan 7TH! All in all I enjoyed the race. Hamo, Kimi all punching away. Massa seemed to get really dicked with having to stay out that lap longer and know idea what has happened to the pace Romain had last year :( Gutted for the guy :(
They openly said they were messing with his head in the off season to prevent some of the issues reoccurring. Maybe took a little too much out of him. Fine line I guess.
I guess that's why it's only a 3 spot penalty instead of the usual 5.
I think ppl underestimate Merc's race potential at their peril this season. But anything can happen... and it probably will!
They're going pretty similar to this time last season, except their lead driver isn't getting mechanical DNFs and Grosjean'ed.
Lewis qualy this year - 3, 4, 1
Schu qualy last year - 4, 3, 2
In the races:
Schu had g'box retirement in Aus while running 3rd having passed Vettel. Hamilton finished 5th this year.
Schu got Grosjean'ed to the back of the field in Malaysia's opening lap, but fought back to finish in the points. Hamilton had an uneventful but heavily assisted 3rd this year.
And Schu was running a comfortable 2nd in China until the pit stop where they failed to tighten a wheel. While Hamilton just clung onto 3rd at the end this year.
Rosberg qualy this year - 6, 6, 5
Rosberg qualy last year - 7, 7, 1
So he's doing similar things apart from not getting the job done in Q3 at China this time. And has inherited the mechanical troubles that plagued Shuey last year with 2 mechanical DNF's for electrics and suspension.
Hopefully they don't fade away like they did last year.
this tyre preservation racing is terrible
this!
isn't it great for the show to see drivers so worried about hurting their tyres they don't bother racing someone for their position because it will only hurt their race by having to pit earlier, stuffing up their strategy.
plus we had stuff all happening in qualy also because of the tyres
good work Pirelli!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
