Paul di Resta has been excluded from qualifying at the British Grand Prix after his Force India was found to be under the minimum weight limit.
The Scot had secured fifth on the grid at Silverstone but his car came in 1.5kg underweight in post-qualifying scrutineering.
Even with a mandatory fuel sample on board, the car weighed only 641.5 kg - which is 0.5 kg below the minimum weight.
After the FIA drained the car of fuel, it was found it weighed just 640kg, two kilogrammes under the limit.
With a 0.5kg tolerance accepted for the scales' accuracy, it was ruled that the car was officially 1.5kg underweight.
After the matter was referred to the race stewards, it was decided that the team had been in breach of the regulations and di Resta was thrown out of the results.
He can now start the British GP from the back of the grid.
It is understood the issue revolved around the weight of di Resta himself after qualifying - as the driver and car are combined to reach the 642kg limit.
There are suggestions that di Resta's weight check at the end of qualifying was 1.5kg below his normal weight - which he had been after free practice.
Although some consideration was given to appealing the matter because of the discrepancy, Force India in the end has decided to accept the verdict - meaning di Resta will start his home race last.
http://www.autosport.com/news/report.php/id/108426
Pos Driver Team/Car
1. Lewis Hamilton Mercedes
2. Nico Rosberg Mercedes
3. Sebastian Vettel Red Bull-Renault
4. Mark Webber Red Bull-Renault
5. Daniel Ricciardo Toro Rosso-Ferrari
6. Adrian Sutil Force India-Mercedes
7. Romain Grosjean Lotus-Renault
8. Kimi Raikkonen Lotus-Renault
9. Fernando Alonso Ferrari
10. Jenson Button McLaren-Mercedes
11. Felipe Massa Ferrari
12. Jean-Eric Vergne Toro Rosso-Ferrari
13. Sergio Perez McLaren-Mercedes
14. Nico Hulkenberg Sauber-Ferrari
15. Pastor Maldonado Williams-Renault
16. Valtteri Bottas Williams-Renault
17. Esteban Gutierrez Sauber-Ferrari
18. Charles Pic Caterham-Renault
19. Jules Bianchi Marussia-Cosworth
20. Max Chilton Marussia-Cosworth
21. Giedo van der Garde Caterham-Renault
22. Paul di Resta Force India-Mercedes
http://www.autosport.com/news/report.php/id/108427
daniel up to fifth place and he starts on the clean side of the track!
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
