Paul di Resta has been excluded from qualifying at the British Grand Prix after his Force India was found to be under the minimum weight limit.
The Scot had secured fifth on the grid at Silverstone but his car came in 1.5kg underweight in post-qualifying scrutineering.
Even with a mandatory fuel sample on board, the car weighed only 641.5 kg - which is 0.5 kg below the minimum weight.
After the FIA drained the car of fuel, it was found it weighed just 640kg, two kilogrammes under the limit.
With a 0.5kg tolerance accepted for the scales' accuracy, it was ruled that the car was officially 1.5kg underweight.
After the matter was referred to the race stewards, it was decided that the team had been in breach of the regulations and di Resta was thrown out of the results.
He can now start the British GP from the back of the grid.
It is understood the issue revolved around the weight of di Resta himself after qualifying - as the driver and car are combined to reach the 642kg limit.
There are suggestions that di Resta's weight check at the end of qualifying was 1.5kg below his normal weight - which he had been after free practice.
Although some consideration was given to appealing the matter because of the discrepancy, Force India in the end has decided to accept the verdict - meaning di Resta will start his home race last.
http://www.autosport.com/news/report.php/id/108426
Pos Driver Team/Car
1. Lewis Hamilton Mercedes
2. Nico Rosberg Mercedes
3. Sebastian Vettel Red Bull-Renault
4. Mark Webber Red Bull-Renault
5. Daniel Ricciardo Toro Rosso-Ferrari
6. Adrian Sutil Force India-Mercedes
7. Romain Grosjean Lotus-Renault
8. Kimi Raikkonen Lotus-Renault
9. Fernando Alonso Ferrari
10. Jenson Button McLaren-Mercedes
11. Felipe Massa Ferrari
12. Jean-Eric Vergne Toro Rosso-Ferrari
13. Sergio Perez McLaren-Mercedes
14. Nico Hulkenberg Sauber-Ferrari
15. Pastor Maldonado Williams-Renault
16. Valtteri Bottas Williams-Renault
17. Esteban Gutierrez Sauber-Ferrari
18. Charles Pic Caterham-Renault
19. Jules Bianchi Marussia-Cosworth
20. Max Chilton Marussia-Cosworth
21. Giedo van der Garde Caterham-Renault
22. Paul di Resta Force India-Mercedes
http://www.autosport.com/news/report.php/id/108427
daniel up to fifth place and he starts on the clean side of the track!
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
