Paul di Resta has been excluded from qualifying at the British Grand Prix after his Force India was found to be under the minimum weight limit.
The Scot had secured fifth on the grid at Silverstone but his car came in 1.5kg underweight in post-qualifying scrutineering.
Even with a mandatory fuel sample on board, the car weighed only 641.5 kg - which is 0.5 kg below the minimum weight.
After the FIA drained the car of fuel, it was found it weighed just 640kg, two kilogrammes under the limit.
With a 0.5kg tolerance accepted for the scales' accuracy, it was ruled that the car was officially 1.5kg underweight.
After the matter was referred to the race stewards, it was decided that the team had been in breach of the regulations and di Resta was thrown out of the results.
He can now start the British GP from the back of the grid.
It is understood the issue revolved around the weight of di Resta himself after qualifying - as the driver and car are combined to reach the 642kg limit.
There are suggestions that di Resta's weight check at the end of qualifying was 1.5kg below his normal weight - which he had been after free practice.
Although some consideration was given to appealing the matter because of the discrepancy, Force India in the end has decided to accept the verdict - meaning di Resta will start his home race last.
http://www.autosport.com/news/report.php/id/108426
Pos Driver Team/Car
1. Lewis Hamilton Mercedes
2. Nico Rosberg Mercedes
3. Sebastian Vettel Red Bull-Renault
4. Mark Webber Red Bull-Renault
5. Daniel Ricciardo Toro Rosso-Ferrari
6. Adrian Sutil Force India-Mercedes
7. Romain Grosjean Lotus-Renault
8. Kimi Raikkonen Lotus-Renault
9. Fernando Alonso Ferrari
10. Jenson Button McLaren-Mercedes
11. Felipe Massa Ferrari
12. Jean-Eric Vergne Toro Rosso-Ferrari
13. Sergio Perez McLaren-Mercedes
14. Nico Hulkenberg Sauber-Ferrari
15. Pastor Maldonado Williams-Renault
16. Valtteri Bottas Williams-Renault
17. Esteban Gutierrez Sauber-Ferrari
18. Charles Pic Caterham-Renault
19. Jules Bianchi Marussia-Cosworth
20. Max Chilton Marussia-Cosworth
21. Giedo van der Garde Caterham-Renault
22. Paul di Resta Force India-Mercedes
http://www.autosport.com/news/report.php/id/108427
daniel up to fifth place and he starts on the clean side of the track!
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
