yeah, if taking out the leader and 3 other cars from the places they deserved makes a race awesome... Perez's tyre almost took out Alonso as well. That would have been even more awesome.
Vettel and Rosberg (and probably many others we haven't heard about) had tyres with visible damage and almost at the point of failure at one of their stops.
it may have made a spectacle out of the race, but it only hurt the actual racing and had far too big an influence on who finished where.
This headline sums it up nicely: Rosberg lucks in to victory as tyre failures wreak havoc with race
Edited by hrd-hr30
As Dan said pre-race everyone thought that tyre durability was not going to be a concern for the race and it was going to be a pretty straight up fight.
How wrong they all were. It woudl have been a perfectly good race if the tyres had not blown up as Vettel on Hamo would have been a good contest and ditto Webber in the back of the top 10 trying to come back through. The DRS zone made life rather easy so didnt need tyre grenades
Too pissed at Pirelli to even bother reading the follow up news
Ruined Hamiltons home race, stopped Sergio from embarrassing his team mate again, robbed JEV for a chance to show his stuff to RBR along with dan, and gave people the opportunity for spectators to sympathize with that little weasel of a joke in the red car
Cant wait for next week, where its just as high speed as this week
Edited by ctjet
Didnt anyone else see the red turtle shells and banana peels? hamilton managed to score a lightning strike on vettel. Webber stuffed up his start but lucked out and drew the flying bomb... Tyre shenanigans aside it made for an exciting race with shit head not coming first for once..
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
