If they were the only two other people in the room I think I would prefer to sit back and have nothing to do with them
Lol.... pretty much
Sucks being out at work while races are on. Only just got to watch it this morning, 2 years in a row I've missed watching my favourite race of the year :(
Sad to see Kimi end his awesome points/race finish streak
Getting sick of Vettel running away with every race now.
Martin Whitmarsh believes Kimi Raikkonen is determined to move away from Lotus and also revealed McLaren held discussions with the Finn last year.
Asked if they had ever considered re-signing the Finn, Whitmarsh told the official F1 website: "Yes, we have. Kimi has always been great and I am a big fan of him. There is a lot of speculation out there at the moment, so let's see what happens.
He added: "I probably shouldn't be, but I'm completely open - last year we had talks with him, but for various reasons it didn't happen. This year we've had no talks - yet."
As for where Raikkonen will end up, Whitmarsh said: "Obviously Kimi is determined to go somewhere else and I sense that he will not succeed in that goal, so let's see how he gets on there."
http://www.planetf1.com/driver/18227/8892110/McLaren-talked-to-Kimi-over-2013-seat
purely for my own entertainment, i sort of want him at the fuzz just to watch fernando's mind meltdown
everybody is too comfortable at the moment, let gets some of these guys freaking out a little
You have to like their chances of being one of the 3 strongest teams next year. They have had a tech re-shuffle which should have cleared the decks which along with a poor 2013 will allow a good run at the 2014 car
Plus, I doubt Perez or Button are getting the most out of the 2013 car. History shows Perez cant qualify and nor can Button and 4 weekends out of 5 Button can't get everything out of the car...so granted car isnt great but doubt its as bad as the results suggest
That seems odd..... Hasnt Martin Brundle driven one of the Red Bull cars (not sure which year it was from) and I'm pretty sure he would be a bit 'wider' then Dan. The new car cant be THAT much wider then the older cars
The amount all F1 drivers train I wouldnt think that this would be an issue for Dan...
I think if Webber can fit, Dan should be able to fit. I'm aware its going to be a new car that Mark wont really have anything to do with but looking at the two of them, they dont look that different at all in build. I would say Dan is probably smaller if anything
More and more chatter about the kimi move back to the red team
Maaaan, I can't wait to see the old hysterical victimised spaniard back!
I hope after this year when vettel steps all over his dreams, he sticks it to him again for the 5th year in a row. Can ferrari absorb all that is hurricane fernando?!
Only 2014 can tell!! What a great silly season
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
