Interesting to compare Dan and Jev?
But the real point that I am stoked about is Romain has been in teh points the last 7 races ,inc three 3rds. The Singapore DNF is the only hiccup and he was in a strongh position when that happened. He is finishing the year nicely!
Its interesting because I have to reach for the excuse jar for Dan. I had through that the stats would have added up rather favourably for Dan given his form post Silverstone.
Doesnt mean anything much Roy. If you drag the smoking wreck of a busted pos of a car home in 20th instead of retiring it you can shift the numbers by one in just one race. The are 3 vs 5 DNFs off the back of 13 races. So JEV has only 8 finishes, Disco 10. A 20th for JEV would make his number worse than Dan's. Also it is hard to "out race" your team mate when they have retired.
Singapore, for example, was a bad race for Ricciardo. He stuck it in the wall from 15th position or thereabouts which helped his numbers.
Edited by djr81
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
    • Yeah you can. Cable tie the gauge to a windscreen wiper, or run it into the car and hold it with one hand, or have the neighbour's kid run alongside and tell you what it says.
