I've got an unreal deal organised for Aussie made carbon oem rear wing and intercooler insert as a package
Guy making them made Mark Berry's 34R carbon dash
Will get more detail up ASAP
  • Replies 71
Think he can throw in a N1 style boot and/or bonnet spoiler for me?
Either case, keep us posted.
Sent from my SC-03D
Hi Guys
Have been busy organising these items below in the hope to get a group buy happening in the next few weeks, prices are as follows:
Rear wing OEM style:
- Carbon fibre
$490 each for 5 orders
$420 each for 10 orders
Intercooler surround Nismo style:
- Carbon fibre
$380 each for 5 orders
$320 each for 10 orders
Package deal for both:
$700 for 10 orders
All prices will be + delivery
Kyle from hi Octane Racing in Sydney has put this together for us. Both items are made here in Aus by the same guy that does the carbon fibre work for Mark Berry...
http://www.speedhunters.com/2010/09/interview_gt_gt_mark_berry/
I have already put a 50% deposit down for both items for the package price and should have photos available in a few weeks
Cheers
Edited by $$slowmedown
Hmmm. I still need to find out more information about a carbon fiber spoiler as opposed to the stock component. I don't exactly know if I'll benefit from it.
At this point, I do want the Nismo style carbon fiber IC shroud. :D
Sent from my SC-03D
Edited by Bigalow
no farks given.
will look shit hot.
damn you and your awesome package deal when ive got no money.
Yeah mate still 100% happening
Waiting on actual photos of product then will get it all organised and post the actual group buy in the group buy section
Should hopefully be next week or the one after
Cheers
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
