s1 stagea ecu is same as r33, aka no nistune, only works on non neo rb25's.
s2 stagea ecu is the same as a r34 neo rb25, only without the traction control......
I use a r34 power fc in my stagea, so both will fit either a r34 or a stagea vice versa.
so to sum it up:
s1 stagea NO!
S2 stagea YES :D
all neo's ran the same ecu
r33, I believe there were 2 different versions, original r33 ecu and some veeeery late model r33 had the r34 ecu's
yea will try it when i get my looms back.
Thanks man, hopefully all works
Except who i got my loom made with said im missing a relay/plug, brown, 6 pin, nissan, off the loom that goes into the passenger footwell near ecu that is main power for ecu/motor??
Idn what the f**k he is talking about, and he cant fix it as he doesnt have any of whatever it is in his shop.
Gayy
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
