To smart R30 people, can the rear brakes off this car be bolted onto a C211 japanese import coupe?
Cause if so i would like to inquire about the pricing of all the rear brakes and also the rear stub axles which i assume are the same 4x1 bolt pattern as the C210
I'll look at all my notes when I get back home. I'm currently in Qld till 6 or 7th and let you know.
Cheers,
Dennis
Works 510, it is a full bride interior, black and grey, but the front seats are sold.
What i am selling ar ethe JIC adjustable coilovers. I am open to offers but would need a set of standard rears to replace them with so it still rolls (i have a set of standard fronts already)
Excellent condition, adjustable tops etc. i will remove them and have a look at the spring rates etc.
yeah i should be able to chase up some stock rear struts.
what sort of price are you looking to get for them?
Any updates for this guys?
Masters, the door trims etc will now be staying with the shell. The shell is on ebay at the moment for those interested, still has most gear including coilovers, bride interior minus front seats, etc etc...will sell entire car for cost of paintjob. the nicest shell i have seen.
  • 4 weeks later...
  • 4 months later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
