  • Replies 128
Shit happens.
Blew a coolant line under my plenum yesterday whilst going for a photo shoot in Canberra for a local calendar. Time and dollars are not on my side.
Have to remove/replace plenum and replace all water/oil lines (to be sure to be sure) !
19th of Jan is just too close now and I'm tight on cashola. Sorry :(
will not be attending after all.
I hope this goes ahead and no one else has to dip out.
Love to see the results (pics).
S!N
Likely back in. :D
Fixing issue on Thur/Friday.
Will be replacing all hoses, replacing Plenum, ID1000's Injectors, re-tune.
All goes well I will be there !
It's well maintained so I dont think there will be any $urpri$e$
I got on it once to check it out and people freinded me and started posting stuff and blah blah. So I shut it down.
Went back last week to check this link...
Will disable again soon before I get any friends and rubbish stuff.
Took me ages to unfriend everyone the last time and clean the mess up. LOL
I be too old to play FB ....
THIS WOULD NOT WANT TO BE AN RTA STING AS WE WONT BE HAPPY
I was gonna say you can always come up with me if your still having dramas Richard.
And yeah it better Fkn not be. Especially if I can't drive home.
Edited by k_d
I might have another 2 R32 GTRs coming up with me on the day. Hopefully the weather holds out. They reckon its guna be shit hot on Friday, so hopefully the sun will follow up on the Saturday.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
