Like Deca? Wish It Were Closer? Wish No Longer! New Skid Pan In Melbourne!
  • Replies 76
I reckon well done to who ever builds a skidpan close to the Melbourne.
I'm still baffled why DECA themselves haven't extended their venues into bigger and better ones, closer to the CBD. With the amount of car clubs and people wanting to have fun in their cars nowadays, a well run and well sorted venue could be a license to print money.
this... a skidpan in the inner suburbs in theory could pay for itself almost instantly, however in reality the pigs would just end up sitting out the front looking for easy defects and the place would go broke :/
also I have no idea about insurance costs for such a venue (would be HUGE)
Yeah I'd imagine that DECA's yearly insurance is probably lower than a dedicated skids place, because it is primarily a driver training (trucks etc) facility. and doesn't AASA cover the club itself for insurance?
Because you'd never get it past local council if you say it's a skidpan. This whole country has gone "hoon mad", Gov't and Council alike are not interested in driver training at all.
Different story if you say it's for forklift training and then use it for something else (until you get that knock on the door of course).
Drag Tag's skidpan is the perfect example of what happens (unfortunately), and 24months down the track i doubt that community attitude has changed for the better.
Sad times unfortunately - but there is mounting angst in the car world at all the bullshit - perhaps if things get much worse people might unite and start seriously protesting it all. If I had time - I'd bloody well drive it myself
as far as i know, this will predominantly be a training venue with additional training 'facilities' in addition to the skid pan.
motorsport will probably be a small part of the revenue i would think, and insurance for that would be similar setup to DECA i would think, cams/aasa - don't know how it works for the other 'training' side of things...
TBH i'm surprised all race tracks haven't been closed by the gov't :/
Tbh I'm surprised the government hasn't opened more.
All profits would go to government
More people of the road and on a track - dream boats don't kill other dream boats
They would sit cops outside to give everyone anal - all profits to the government
Tbh it would be a very revenue effective business for the government
I'll just stick to the paddocks then ;)
  • 4 weeks later...
Hey guys, I was pointed to this thread my a member here. Just so you know, the skidpan has full council approval for driving training just like that of DECA and will opperate in like manner. During the week it will be used for truck and bus training, during the weekends it will be used for cars just as DECA is right now.
No broken pipes, but there is an abundant water supply if required. There is a slight gradient of 2° across the skid pan to allow for water to gently roll down the full face of the pan rather than having some areas dry yet other areas pooling water. It's a well designed driver training centre.
Light's are to be the next thing fitted ( evening skid pan work anyone? ) which is something different I think. While it's true there is no highway circuit like that of DECA attached, there are plenty of race tracks around VIC for those wanting to participate in motorsport in an environment like a circuit. Sandown being the closest to Melbourne.
However, unlike DECA it's not a 2 hour drive from Melbourne for those wanting to have some fun and sharpen driver skills in a safe environment like a skid pan.
Well then it's just not like DECA is it? :P
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
