Hi all , I've been having some dramas with fuel leaks on my R33 at the fuel filter . I was under the impression that these cars used 8mm or similarly sized high pressure hose but I don't think this is the case . When I started using Eflex E70 I changed the filter for a new Z201 and fitted new EFI hose as well . Long story short I kept smelling wafts of fuel and finding leaks on the lower side of the filter . Funny thing was sometimes it leaked and sometimes it didn't and no amount of tightening made a reliable fix . In the end I replaced the filter again and refitted the original I assume factory hose which is in reasonable condition - and doesn't bloody leak .
I did some research because I used to know of a workshop that stocked a large variety of low and high pressure fuel hose including 7.5mm . Wurth stuff I think it was .
It seems that Super Cheap advertise 7.5mm fuel hose which I'm going to look at later today and I'm taking the used filter and some of those nice Nissan style stainless clamps along too . One thing you ntice with the OE Nissan hose is that it has a smaller ID and OD and the std clamps struggle to get over the larger 8mm or 5/16" ID EFI hose .
Also , I remember reading here in the past that the in tank pumps EFI hose isn't the normal stuff and using regular EFI hose causes dramas . I found this link to a Gates page that quotes some SAE fuel hose standards and interestingly they talk about special linings for nastier fuels - like current low emissions stuff and ethanol . They ALSO mention that in tank pump hose needs to have the special lining on the inside AND outside to stop it swelling failing or whatever . It makes sense that hose manufacturers are not going to spend money on expensive outer linings for external hoses when its not needed but they have to when its exposed to fuel in a fuel tank .
http://www.gates.com/common/downloads/files/gates/brochure/techtipsform.pdf
Fuel hose has to be right for obvious reasons and it would be soul destroying to watch you car burn to the ground by the side of the road .
A .
https://www.sau.com.au/forums/topic/414933-efi-fuel-hose-sizes-and-standards/
I don't know if outer linings are helpful for in tank installation. After all, you have two cut ends on each piece of hose, and outer coatings won't stop fuel penetrating the inner layers. Fuel hose for in tank applications is fundamentally fuel resistant, all the way through.
From memory it is 7.5mm hose as you suspect, not 7.9mm or 8mm. I have sections of all sorts of hose in the garage, never know when I needed something and the R33 used to be my only car. I measured the pipe diameter of the fitting and it is smaller than 8mm, so I used 7.5mm hose.
I decided to stick my Verynear calipers on the just removed Ryco Z201 and was surprised to find its inlet tube is slightly smaller than the outlet tube .
The inlet side OD is ~ 7.91-2mm and the outlet is ` 8.00-8.02mm .
The box says made in China for GUD which looks like Ryco in Victoria ...
I wonder if this is a screw up on the manufacturers part or if genuine filters are like this too .
In my case these "Ryco" filters only leaked on the inlet side and the only difference is the tube diameters , it must be just enough not to allow the 5/16 hose to clamp up on though it always did on the cars steel tube side .
I think I'll start using genuine filters if the price isn't stupid .
A .
On the subject of filters people elsewhere are reporting start up rattles and anti drain back valves not working in "Ryco" oil filters .
I'm actually getting a bit of this and I remember thinking that the last Z145 I bought was remarkably cheap .
On site reckoned that Ryco Aust was trying to take their "supplier" to task over manufacturing faults with a number of fuel filters .
Does anyone have the part numbers handy for ECR33 oil and fuel filters ?
Cheers A .
just checking Disco but you did use proper fuel injection clamps ..not normal hose clamps..I got these for 1$ each at some speed shop...worth replacing..
just FYI i'm using Conan 5/16 hose...seems to work alright was cheap too
I use the same. For clamps I go down to the local pick a part and fill my pockets with old merc worm drive clamps :) they shit all over locally available shit and don't cut into the hose.
ryco Z200 fuel filter and nissan oil filter.
Edited by battery
The hose in the fuel tank is a butyl rubber inner and outer, where normal EFI hose for outside of tank is butyl inner, nylon type crap outer and not fuel resistant.
Someone decided to use the nylon outer EFI hose in a fuel tank once, I changed a mates fuel pump and found crusty bits of fuel hose and pieces in the tank lol....
The fuel tank genuine stuff is like $120 a metre or so.
Yep I've always liked Nissan OE fuel line clamps , those narrow band Wormald style ones are a last resort .
The hose I had used was some American marked -7 5/16 stuff .
Going to check out Explosive Racing at Peakhurst tomorrow , cheers A .
And I will be measuring the barbs on the filters too .
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
