I forgot about the ducting photos.
These two arent from an australian supercar they are from a current Newzealand V8 touring car.
They run a controlled Wilwood calliper and controlled brake duct.
Our local supercars use an almost identical ducting setup thats kevlar.
Hi sorry if I might be hijacking your thread, but this seems to be the best place to ask.
I drive a 99 R34 25GT, at the moment it's a daily driver but it's also a long term project car (Engine won't really be touched until I get myself another car for a daily driver).
I've taken it on one track day so far and I'm looking at taking it on the track a couple of times a year if that, nothing too crazy.
But I'm looking at upgrading my brakes with a big brake kit. I was looking at the D2 kits but I'm not sure what I should be getting. Can someone please give me a couple of options on what to get? I'm not sure on rotor sizes either. I'm hopefully getting TE37s soon also so they would have to fit under those..
Thanks for any help in advance
So is the air and water vapour mixture just directed onto the face of the rotor on that side?
The 330mm D2 kit is the safe bet, they will fit under most 17s. If you want the 355 you will need 18s, the TE37 design is great for caliper clearance and should not be an issue. Really, the question should be what size tyres do you want to run (17s are much cheaper than 18s) then choose the wheel, then choose the larger or smaller brakes to suit. Either kit will be fine unless you use the brakes more than you need to ;)
Brad, we need pics of the other side of the rotor...I'm willing to bet the vent runs to the centre of the disc not the outside face, but that's not how it looks in those pics
here is a couple from both sides of a VY taxi.
This car has a front mounted rack unlike the previous car that was rear mounted.
The ducts on this one are mounted at the front of the upright obviously.
The NZ VY has a very similar thing but smaller.
There is a carbon peice that locates onto the duct which adapts into a 3inch spiral tube to allow the flex before entering very similar kevlar ducting to the front bar.
The kevlar parts from that VY are removed at the moment and being repaired.
lots of space when there is no driveshaft going to the hub eh? Interesting the shape of that final duct, I bet they have done a lot of testing about how much air to aim directly at which part of the disc vs how much to direct at the centre
Real race cars only have two drive shafts Duncan ;)
I wouldn't want to change the ducts that's for sure. That car has done 3 Bathurst 1000 events and finished all 3 times as well as sandown enduros so if say they did something right.
The differences between teams is interesting to look at though.
A lot of the time they run the cars with the ducting blocked off at the bumper.
Spot on the money. There is a properly made up funnel that crates a neat shape that suit the inside of the rotor.
Jacking up a supercar now to take photo of it.
I see said the blind man! Great job Brad, thanks mate.
No kidding with space due to no driveshafts!!!
Anyone wants Alcon rear kit ? SInce they offer free shipping for rear kit, I will order it, and will keep it for spares, but I thought if anyone wants rear too we can drop price little bit http://www.jdl-brakes.com/alcon-adv-extreme-brake-kit-rear-4-pot-o350x28-nissan-skyline-r32-r33-r34-gtr.html
Anyone wants Alcon rear kit ? SInce they offer free shipping for rear kit, I will order it, and will keep it for spares, but I thought if anyone wants rear too we can drop price little bit http://www.jdl-brake...33-r34-gtr.html
I got mine Alcons from JDL, great service and stuff
These seem to be pretty cheap http://www.ebay.com....=item2ec12dc8e3
Does anyone have experience with them?
I bought my first R32 GTR with Wilwood 330 mm kit on it. It was good, but not better than Brembo from R34 which I fitted few months later. Maybe I had some issue with pads from this kit, and that's why it didn't perform as it should. Anyway, I wasn't happy. It's still my #1 http://www.jdl-brakes.com/special-offer-alcon-adv-extreme-brake-kit-front-and-rear-nissan-skyline-r32-r33-r34-gtr.html
Those wilwoods are a very average setup overall.
The callipers have a terrible open bridge design and they flex horribly. The lug mounts they use also flex a lot if you dont have the callipers spot on centred to the rotor.
I've used them on lighter road cars like MX5's and pulsars in the past with little problems
I fitted a set up to a Toyota 86 a fortnight ago only to remove them after a track day and change over to an AP calliper. The pedal feel was horrendous at 3 corners at Wakefield park.
AP's being tested on Wednesday but already on the road they feel so much nicer under firm braking.
  • 3 weeks later...
I have Alcon front kit with 343 mm rotors, but thinking about these kits http://www.jdl-brakes.com/special-offer-alcon-adv-extreme-brake-kit-front-and-rear-nissan-skyline-r32-r33-r34-gtr.html What wheel do I need to clear 6 pistons calipers with 365 mm rotors ? 18x9 +15 would be ok ?
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
