  • 3 weeks later...
Im chasing the following parts for an r32 gtr.
Bootlid with spoiler holes
Rear spoiler
N1 bootlip
Front guards
Front part of the sideskirts that go on the guards
Bonnet
N1 bonnet lip
Front indicators
Lower lip
Grill
Intake duct that goes inplace of headlight
Trojan have a 32 GTR wrecking.
I think the boot and spoiler are on it and front guards.
John the legend sold me some trims out of it for cheap as.
hows the dash look? are they there tomorrow? Edited by natett
Yes i could delete one of those bovs.
Hmmm.... dunno if its worth getting and putting on the forward plenum, its because i want to organize the engine bay a bit better, but i dont know if it will really help.
It would eliminate the crossover pipe, and give me room behind the radiator again, but i think i wont be able to fit my engine damper, and ill have a bov stuffed down where there is already a few hoses and sht.
Cant drive it, so im getting bored and want to do stuff to it. Plan to: get good headlight globes, put my new brake pads on, get some better seats, fix the heater for winter, move the oil temp guage, fix the window winder relay and switch, get a slimmer intercooler, get a new windscreen fitted and give the car a polish.
And a tig welder, i want one for this pipe sht, id just make it from bits ive got
Edited by D.I.Y. Mik
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
