i traded my old wheels for them on gumtree, but ebay has a varrstoen seller which seems legit.
had some basic coilover i found on this page but might upgraded later on to bc's
all i needed to do was rolled the guards and had to shave a bit or my rear bumper lip inside and also camber
hope that helped rawzz
Thanks Mate.
Yeah I ve sent messages to varrstoen aus via their website and ebay page but no reply. I wanna know whether any of their te37 or ce28 reps come in 2 tone ( polished dish and black spokes).
Thanks Mate.
i used to chat with that guy, forgot his name though. Varrstoen is quality rims and if ur not a brand whore or after a seriously light weight rims then its the way to go. any of their rims comes in matte black as standard, any other colour , even custom will cost extra 100$ per rim, so do ur math :). order from varrstoen website directly is a bit cheaper. if you google u will find his number :).
actually, just found in an old thread, here is the details
Hello Mate,
I am the Distributor for Australia !
I think you have addded the Varrstoen Aus page on FB but our office number is 075444 4784
Hope to hear from you soon
John
Been an exciting couple of days.
There is so much win right here. Its going to be forking awesome!!!
High five to not having the right motor in your V35. Post up how its going. In considered this in my sedan but its been done so i didnt.
Moar pics and sounds when its done!!
  • Like 1
Cheers mate, Dunno if its the first in australia can't seem to find anything over the net.
some people are with it and some are against it.
Can't please everyone now lol
More pics to come when turbo is mounted. Yes you heard correct, Turbo!
Tell them to get f**ked mate. Theyre just a tad jealous they your doing something different. Im getting the same off people.
I know a guy in the states who has done it in a sedan. But in aus i think youd be one of the first if not the first. I rekon a supercharged V8 with the whine would sound tits.
F**k what people say. Its your car, your choice.
Good on ya man!!
Edited by Howaitonaito
like like like like!
Whats the plans for the car, track drift, or just street?
Good on ya man!!
Cheers mate, appreciate the kind words!
Didn't want to spend the money on the crappy VQ donk.
Originally was just gonna be N/A with a big cam and nitrous but bit the bullet and going turbo.
Just a street car/drag car with the occasion powercruise and that.
It's got a built manualised TH400 behind it.
Im swapping to the stagea VQ25DET donk. I dont mind VQ power actually. It has its own unique sound and qualities. If i had the choice id got VQ over RB. Id go a rotary over an RB. Just so common and over done here. I can understand VQs arent to everyones liking tho and this will be awesome.
What state are you in? I know that in Qld, a car can't have an engine with a displacement greater than 3 times the cars weight, with a turbo or supercharger.
I was contemplating a 5l V8 with a decent turbo but the rules up here wot allow it.
Biggest I could go was a 4.5L then add a turbo - which is still tempting.
One of the guys up here put an ls1 in a 33 and then realised, far too late that he can't boost it. Just a bit of a heads up mate.
Hello Mate,
John
Thanks Justin,
I am not in a hurry so I didnt bother calling them, just emailed to see what they have but they seem that they are not checking their emails.. :) will give them a call when I am planing to get the wheels maybe next month.
Do you happen to have the SAU forum user ID for this guy by any chance so I could PM him?
Thanks
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
