I Grabbed some from OTR for my Nismo LMGT's. Could have bought Nismo nuts but decided to get some alot stronger for less than half the price.
Dont under estimate the value of a good set of nuts. I prefer steal (lol). Give them a call and you'd be surprised about the price :).
Unless your after 1/100th of a second I'd buy something that may be lifesaving over wheight saving.
You also couldn't go past Rays. They make great rims so you can expect their wheel nuts to be great too.
i have nismo wheel nuts.
i have thrown alot at them, and never a problem.
so long as they are torqued correctly when put on.
also, on your rays front, nismo also make quality items, so their wheel nuts should be of no exception, which, they are not.
ot, bought an engine and machined flywheel for the hilux this arvo.
$2 for both.
gotta love ebay.
motor has stripped dizzy drive gear on cam, not worried, as it will be replaced.
Anthony, thanks for the offer to help pull my dash out. I Got lazy and didn't want to spend several hours on it learning as I go.
So I got Audiotech on the job today mate. After things like glove box, centre stereo and consoles removed, apron under the steering wheel
Turns out that 2 small screws and 2 bolts/nuts hold the dash itself on. Amazed !
Upshot - my existing dash will be available by the weekend. If you want it come get it Friday/Saturday (and pay later :))
I already got a dash off you bro! haha. well im glad the new one is in. Let us know if you ever need a hand. Out of curiosity how much is it costing for them to do it? i have yet to decide on if i will bother to do it or pay someone. Though my job runs out in 3 weeks and im still trying to find a new one... how fun. Richard i still owe you $150 from the other dash. When i get a new job ill come round with what i owe you. I also can't find that fking boost controller.... I think i have gremlins stealing from me.
Note to self: new pod filters, Cams, Haltech or z32's (yet to decide) and i said my GTR was finished in the engine...
I could never have been so wrong...
Shite - thats right. Hmmm
Anyone after an R32 dash. Suits all 32's
Has a minor bubble' and a plug to cover a 5cm hole. All in all it looks good........just not perfecto
I have all of the Blitz Dual SBC stuff except for that display/control :( (this is good stuff).
Haltech does all the shite now :D
Looks tasty. :thumbsup: Did you pull them off to do it or just leave them on and mask everything?
Wanna do this too, Black with Red NISSAN. :D
I left them on and masked everything. I didn't want to bleed the brakes.so took a shortcut. It will look better if you took it off and the clips I'm yet to sand paper the Nissan out and paint it silver or white.
buy haltech.
i have pods for sale.
m's elbows with unknown filters.
sitting in the garage not doing much.
I have some Apexi pods for sale too if that helps you at all Anfanee :)
This one:
http://www.nengun.com/apexi/power-intake-gtr
Came off mine when I went to single turbo. You can have for $100.
This one:
That would be great, Want to bring them with you on Sunday and ill grab them off you? ill scrape $100 from the missus =P
Finished and installed my DIY Pod Shield. (just needs some rubber round the edges.)
Amazing what you can do with a coat hanger, texta, cardboard, perspex, a renovator tool and a heat gun. :laugh:
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
