got a metal inlet/exhaust gasket kit, few speedflow fittings, oil pump and gasket ahead of the weekend. No fkn way im gonna be pulling this motor out again lol. On that topic, anyone got a black heater hose kit for 32 gtr laying round?
All good man, Im really after the hoses under the plenum as i vaguely recall someone telling me they split in their old age...
Or maybe after watching your car piss coolant at the calendar cruise i realised that sucks and i'd rather not have to pull the motor again :)
split dump is fouling the wastegate for some reason.
dunno why... it worked fine for ages, now i cant grind enough out to make it work, ill grind through.
wtf happened? dunno.
Time to get a bellmouth dump, maybe all new system.
7 hours and no luck...
you need a break, eat & drink for brain power, do some reading on the forums, and the solution/problem will become clearer.
We had the works !
Drinks and Rob (Not a Pulsar) on the phone giving us guidience, also Google was a bit of a mate on the night.
A lot of it was testings up the road so pulling in and out = sucked. But, some boys on SAU reckon they've got the fix. My Spark plugs may not be "gapped". So will check that and HOPEFULLY it'll stop misfiring.
Trying to figure out Overheating when sitting above 110kph..
Fresh coolant and clean, no luck..
New thermostat and more coolant. time to test again, fingers crossed.
Slight change in temps across radiator, so maybe some minor blockage there, look into a proper flush next, or just upgrade it as I want to do that anyway..
got motor out, changed all the water hoses and inlet gaskets, removed the remainder of the wtin turbo water and vacume lines that arent used and tidied up the engine bay a bit. pretty productive, not as much as id hoped though :/
no wheels for me tomorrow so yall have fun without me
Are you painting them another colour?
I really wouldn't mind painting mine
I was considering painting the centers Black but after the enormous sh!tfight I've had stripping them I might leave them as is.
I do like the result alot. You reckon I should paint Black or not?
Much better than the uneven goldish crud they had when purchased. (SAU Third or Fourth Handies)
Crimson Inc. Linea Sports (made by Sparco)
post-78856-0-06591100-1363429754_thumb.jpeg post-78856-0-48300000-1363429506_thumb.jpg
I have painted some R32 GTS-t rims before and it was a heap of fun. Not bad result either.
Looks good. Painting those wheels black may be too unnoticeable. How much did all the stuff you need cost? Im convinced I must do this now.
Any ideas what colour wheels would suit maroon?
So far the paint stripping exercise has cost me less than $40. Paint stripper gel and wire brushes. I bought some brushes to use on a drill but they got little use. Hand job FTW!!!
The painting of the GTS-t rims was all done with cheap cans from Supercheap (except the primer) but if I do it again, I would use better paint like engine enamel as it should be tougher and longer lasting.
OT. I washed my car and drove it to "WHEELS" at the Racecourse. With the wind and dust, it is dirtier now than before I washed it! :(
Show pics of car with rims you want to paint for colour choice suggestions... Black, Gold or Bronze should be good with Maroon though. :)
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
