go on, let me in your 32.
last one i sat in still isnt running...
I lived with Richard for 18 months and never got to go for a ride :(
Haven't gone for a ride in his 32 either!
What did I do to my car today ? Ummm - picked up a parking fine.
Went for another spirited drive after work out through Tharwa and looks like I' need my clutch rebuilt/replaced now.
Living life a quarter of a mile at a time. Tis expensive lulz !! Launching can = lunched :P
having an awesome weak. Caught up in 3 queues due to accidents, 1 parking fine and now a lunched clutch.
Well I shouldn't really complain as the OS giken twin plate has been in since before I bought the GTR 10yrs ago.
You have to expect to go right through your drive train from engine to rear diff over time. Shift the power to find the next point of failure.
GB next ? yes it's likely.
Last night I took the gearbox off again and replaced the front cover allowing the thrust bearing to slide all the way back, so no more slipping clutch :D
Today I got a buff on the car and got my drivers seat back from my upholster. Wont be able to fit it today as I just got home from ED after slicing my leg with a box cutter :D
Edited by Zippo8
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
