Tidying up my man cave today.
Going to clear out my garage and use that concrete paint on the floor.
Have painted too many small parts on the floor of my garage. So has templates of parts all over concrete - lulz.
R32GOJIRA is dropping off rocker covers for me.
Will get them professionally coated and put them on soon :D
and that's what I'm doin'
and yes - Zip ties (have 3 sorts if you wanna come round Eric)
Edited by Sinista32
What a s#*t fight that was.
The pod enclosure doesnt fit right and consequently partially snapped. One of the bolts does not fit on the front. Had to aryldite the place where it partially cracked.
Air guide fit ok, not real flush against the top of the grill though.
The perspex it is made out of is too thin. Quality not to flash really.
I will be writing into where I bought it from.
Looks ok for now. I will buy some metal ones I think!
On the up side I fixed the part of my grill that I found broken!
eXcuse me if I sound happy. I am
S!Ns man_cave grand re-opening Wednesday.
needs another coat tomorrow :yes: currently watching paint dry - Tee hee
Got the rear view mirror last week (thanks to ...well you know who you are. cheers for all the OEM parts this year :yes:).
All painted satin black & installed.Need a few more things :)
Saw your post and expecting some good things coming your way - can't wait !
Ordering a complete new lock set and ignition barrel to install. Boot lock doesn't match key WTF, think in the mix n match I've lost it :(
Thinking I will cut my Nismo key to suit (not much use just to keep looking at it). :touch: has to be 50 killerwasps right there.
Edited by Sinista32
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
