Went to drive it the other day. No spark... Dead battery after sitting untouched for 2 weeks whilst on holiday.
So got the new one in today. Changing a battery should not be so bloody annoying!!!
Trying to get the amp out which is mounted on backboard behind carpet wall, then trying to line up the holes again to put it all back in.. sheesh
5 minute job is now an hour!! Glad I won't have to do that again..
strut brace wasn't so much an issue, as i replaced it with another skinny one, so slipped straight under.
A little fiddly getting to the terminal bolts though. Worst of it was just the mounting for the amp. It's mounted to the frame the battery sits on =S
Bought some steel for front reo, when i was in mitchell i dropped into trojan.
He has 18" gold Volk GTC rims. They fit. I like. I like price.
Are they good wheels?
I mean have people had probs with them?
GREAT RIMS - I have :yes: on my 34 GTT.
Check they are 18's.
I know he has a set of 17"'s
No problems. One of the best
Rays Engineering - cant get better
Edited by Sinista32
Thanks, will check.
They look in real good nik too.
9" for the back and 8"for the front.
No...
17"x 9" all 4
Hmmmm.... maybe i should keep looking.
Edited by D.I.Y. Mik
Today i rebuilt the often intermittent R32 headlight switch. I Basically just pulled it all apart and sanded all the contact points, tested it out and it still did not work. :verymad:
So i pulled it apart and had a closer look at how the switch worked, everything seemed to be fine. However i thought it was worth trying to put more pressure on the contact points by stretching the spring mechanism about 1.5mm and it did the trick and now both headlights work.
The 3 black points have little springs under them that can be stretched to make the contact strong and also gives the switch a much better feel.
3e15f193-3a74-4f3f-9bea-fbf4ce78fbe9_zps
Also took the car out to check tire pressures
e540a509-3597-4f65-b94a-4f7148741bf4_zps
Confirmed my Central Locking is not working properly, could be from recent rain??? or the other night when the alarm went off cause of keys in my pocket.
Pretty sure yesterday the drivers door was the only one that would lock / unlock. (which is wrong)
Today the Drivers door is the only one that doesn't work. :(
Edit* Also, while looking through the paperwork I got with the car, mostly looking at the Alarm instructions etc, I flipped through the import papers. (guy I bought it from imported it.)
I can see that it says something about Auto to Manual conversion but I can't read Japanese (can anyone Help?) unsure of odometer reading at time of conversion...
In the pic of the car I can see it had Series 2 tailights on it but it landed in Aust with Series 1s. (confirmed by previous owner)
but also it looks like it had R33 GTR rims in Japan too but landed with 16" ASSO rims. :( No Fair!!!
r32 batteries are easy to change ;)
Time to re-arrange the front bit. Its too crappy.
Now i have a welder and some steel its time to make it nice.
And shorten those pipes, with an intercooler flip.
No butchery this time, its cut and weld it good time.
This should be part of my "final solution"
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
