Took mum for a drive in Rosie - she was superisingly pretty good haha. She used the turbo twice (barely if that) kept gear changing at 2,500RPM - she was pretty feaked out when I took her for a spin and I barely put my foot down :( But a good drive nonetheless. :D
Hahaha! Cool. :cool:
I had both Mum n Dad in my car a couple of weeks ago, we were talking about turbos and relating it to how Dad drives everywhere at low revs. (3 L V6 Navara)
So I showed them the difference between doing 80km/h in 5th and 80km/h in 3rd. :laugh: Certainly got a reaction.
I've been a little Freaked since Friday cause my car started making a weird whistling noise.
Thinking maybe the worst (turbo) or split hose, belt squeal etc but it was really inconsistent.
Speed seemed to contribute towards it but it would also do it at low speed or stopped and idling.
Free reving or Boost didn't really seem to affect it in the way you would think. :unsure: Puzzling...
Sounded like that whistle you get sometimes with a roofrack or something outside the car whistling thru the air...
:whistling: Turns out, one of my dash vents was closed and the air rushing thru at speed or even with the fan being on was causing it. :whistling:
:rolleyes: Thank F**k!!! LOL
  • Like 1
Spent ages making a perspex box... and snapped it on install. >_<
Got a few more bits in the engine bay, got my oilcap today same as robs.
Spoke to Award diff and gearbox, no 1.5 way diffs for 6 weeks, Kaaz is behind in manufacturing, and Nismo got fked up by a tsunami.
Going with a Kaaz 2 way. 1800 and something dollars for a properly installed 2 way, thankyou. Couldnt do it cheaper if i did it myself.
Should be ready monday, which means ill have it back and installed by friday. :banana:
  • Like 1
Found an extra 20 wasps hiding in the top end.!!
Had Safc2 tuned, plugs gapped at .7, and no air leaks found =)
A little disappointed that no correction below 4000rpm, so no better fuel economy around town, but i guess that's a good thing..
Happy days! :woot:
Now just need to save $2k for new new turbo.
  • Like 1
AWESOME!!! SAFC FTW!!! :thumbsup:
They should've done the low throttle map too. :wacko:
You got 0.3 kw more than my first tune too.
Nice one James. :ninja:
Hiflow from Hypergear for $1000.
  • Like 1
Happy days! :woot:
Doesnt matter lambada sensor will control efficiency.unless you drove at wot all the time
Got the Final tune done.... She is complete. Extremely happy. No more work to be done at a shop until a throw the haltech in later this year/next. Next: Engine bay pretty up.....
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
