Got my rear tyres fitted, 255, 40, 17. Must massage the guards out a little more, 10-15mm.
Got the box made last night, to cover my wiring mess. fits good, and i didnt snap it this time as ive made it stronger.
All the little hoses and bits connected up, now i have to make some bits to mount the oil and pwr steering coolers properly.
And then more stuff to make properly, no more bodgy brackets with rivets and stuff. Radiator top brackets are going to be tricky to make look good.
Gave my back a good twist this morning, so i was like an old man all day. Last nights chilli & pepperoni added to the effect. :blink:
But i did manage to get some stuff done, a bit of fabricating, new steering cooler, getting it together.
post-89755-0-18131700-1380958611_thumb.jpg post-89755-0-75342700-1380958631_thumb.jpg post-89755-0-89774500-1380958651_thumb.jpg
Looking Tidy Mik! :thumbsup:
Installed my catch can, put on a Freshly painted Black Valley cover and also a black painted turbo heatshield.
post-78856-0-49547700-1380968573_thumb.jpg post-78856-0-11968600-1380968806_thumb.jpg
She must be happy, you can see her Aura. :D
Tomorrow I pull out the Intercooler and clean all the oils out.
  • Like 1
Cleaned out the back seats and floor mats and door cards with the shampoo vacuum.
This was the result.
Also pulled out my 02 sensor to have a look at at, Looks to be the original one =\. Hopefully my new one rocks up before I go back to work on Thursday.
If the weather is good tomorrow i'll knock up some brackets and fit my greddy oil cooler.
I keep thinking my car is all good then i see the front =\ Fingers crossed the panel shop calls me before friday so i can get it fixed.
Edited by azathoth
Fitted the oil cooler. Lines took ages to run because we couldn't work out where they were meant to go then found a picture online.
Just need to get a smaller diameter oil filter because the z145a fouls on the sandwich plate.
Once i find a filter that fits I can start it up and check for leaks and relocate one of the horns and the air temp sensor.
why you no listen
Z442 which is slightly smaller in diameter and height (in comparison to the Z145a
Finished the engine bay finally. Took a lot longer than i thought it would.
Thats the problem with too many mods, you have to work it out yourself, how its all going together.
post-89755-0-06336700-1381229250_thumb.jpg post-89755-0-76025000-1381229265_thumb.jpg
Pipe didnt fit, things have moved about 15mm, lucky i had some extra bits to make it work.
A transmission cooler off a ford at the wreckers, nice and solid, for a return line fuel cooler behind the diff. And $115 delivered, cheapest i could find, made in taiwan.
post-89755-0-49355800-1381229286_thumb.jpg post-89755-0-98304400-1381229303_thumb.jpg
Old and new.
post-89755-0-10182800-1381229551_thumb.jpg post-89755-0-15340100-1381229337_thumb.jpg
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
