Yes. custom with a mid and rear oval muffler (should add free flowing 350+kwa)
Also have a 5Zigen axle back oval muffler
Edit: both can be classed as almost new.
Edited by Sinista32
If the weather is good tomorrow ill be throwing in my new thermostat, compression test, replace my atmo bov with a plumb back, replace my intercooler and piping with a blitz turn flow kit and put on the cold air box. When my car finally gets back on the road it will feel like a new car. Also have a set of jic magic coilovers on the way. Will be wo much better than Gabs in the front and bc's in the rear.
Yes, Cooma Run = FUN! Thanks Mik!
Got my Magnaflow Muffler on, Love the look and the quietness.
Surpirisingly it took away all exhaust drone even though it's as straight thru as the Canon.
All flanged up so I can chuck the canon on anytime. ;)
Needs Less HICAS :yes:
Doesn't give me problems and if it does, I have a spare. :D
If the weather is good tomorrow...
Wow that's a list! Compression test will be interesting.
had a coffee with mine - that is all :/
handed over spare exhaust system (for $$)
sorted and boxed spare parts, threw some more stuff out
oh I did have a go at installing some bonnet struts on the 32, very easy, but still needs minor modification to fit - thanks to grinder MiK who's on the job.
boomerang trolley jack came back
Don't throw any 32 parts out :ph34r: Never know what someone might need...
I pulled the Space saver out of the GTR and started to design a custom toolbox that will fit in it's place.
Also cleaned the interior properly for the first time in months. Steam cleaned the car mats and the seats. Car smells like new again!
Ran out of my favourite detailing product. Must get more. Hopefully the weekend has some nice weather so i can jack the car up and clean underbelly.
Also noticed my brake discs are starting to Lip. Good chance as any to upgrade....
Am also getting full braided hoses made up for the entire engine bay (Radiator, vacuum lines, catch can, Fuel pressure reg, etc....)
This weekend provided weather is good: Painting a HEAP of a parts. Pulled off windscreen wipers, washer bottle, door trim, and still more to come off.
All in all getting there. :yes:
Threw the f**k-r in the bin after chasing an intermittent missfire problem.
New OEM coils installed... no dice and expensive. Now have 6 perfectly good Yellow jackets sitting around.
New sparkies installed... no dice.
Took it to ESP for them to have a look. no dice so far.
You have to be kidding me....
Next step... Loom?
I'd just wait for ESP to find it. If they can't figure out what the issue is i would be questioning taking it there in the first place. Possibly AFM, or you might just need a re tune. Who knows. The joys of owning performance cars :yes:
Frustrating. ^^ No AFM, is Mafless with ViPEC. Recently re tuned, so I doubt it would fall out of tune.
Yes, this will be the last car I will modify for a while. I keep ruining them.
R32 GTR - Ruined. more time in shop than on road
VN Supercharged. Runied - sounded like the world was coming to an end. Had to drive around with blower off.
VE SS. Ruined. Biggest cam in the world x Shuddering POS clutch, coilovers and more drones than the empire.
Why do I keep doing this?
End Rant.
End Rant.
Could just be shitty fuel. How new are injectors?
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
