what did you use to re-seal. I may have done the same thing. What does it do? or just use more fuel? I wiped mine down not scrubbed it, so was it a hard sealent??
It seals the throttle body and stops it from being a vac leak.
My idle has been screwed ever since I did it haha.
It's just like a thick grease like substance, that's why I mistook it for blowbye.
In robs first pic the top boost line has been cut and clamped and the black wire has already been earthed. But I haven't seen it hit 6psi
Do you have an aftermarket boost gauge or only the stock one in the cluster?
Stock doesn't read in psi.
not sure with 33s but it should be 650 to 850. but it also depends with the temperature of the engine if it cold it will idle higher as the 02 sensor is still working on calculating the fuel mixture. If its warmed up to a certain temp then the rpm drops. or you have your AC on or heater. Or even a hetkik sub will drop your revs when pounding
theres also parallax error that could actually be a 900rpm but the way you took the pic make it look like just below 1000 lol
Intake Air temp sensor its one of the things my ECU needs if it gets too hot it reduces timing.
ohh its one of the things i did today tested out my tig skills from Tafe and still not too bad left a hole at the start
Yea. That was warm and the sub wasnt going hard enough to drop the volts. Also the timing belt wines really bad :/ don't know what that's about but I'm not liking it !
Oh ok. Thought it may have been something like that. Would be interesting to have a gauge/readout on that too.
Timing belt could need replacing or if it's a "Gates Racing" belt they are noisey. Mine was.
And Bryce that welding isn't to bad !! Here's my go at it haha
The outside is a lot better. Just filled in some gaps so it didn't leak
Edited by ..::R33GTS-T::..
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List:
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
